Hi all, I need a radiator as mine is still leaking and I am finding it bloody difficult to get it to a repair shop as I work 7:30-5:00 and only have a half hour break at a time.
So if anyone has one or can even fix mine that would be sweet
Radiator Needed
Radiator Needed
Lubrication Specialist
Lubrication Engineers
Re: Radiator Needed
What side are the outlets on and what size are they? I have a radiator lying around that I had in the Samurai which came out of a Ford Courier and it has both the outlets on the right-hand side of the car, it's in really good nick and has a new 14" electric fan on it, and wiring to suit, yours for $100 if you want it/can make it ft.
Re: Radiator Needed
outlets are at opposite ends. so this will be no good really. thanks all the same
Re: Radiator Needed
Can you send someone to a radiator shop with it?.
If you get really really stuck, i have a couple.
Re: Radiator Needed
maybe, I will see if anyone has some free time coming up. SP may be able to
