gimmemud wrote:whats the centre console like and does it have a heater. dont want heater but my fabrics all ripped and the rest cracked. also how about the steering shaft cover on the inside??? cheers, tim
console gone, will check the rest when im at work.
lockie wrote:how much for the diesel pump. is it the black top motor or the grey top an how much for the intake manifold
make an offer... will check to see if it black or grey
UBZ wrote:Is the front diff head available and if so what ratio is it?
Cheers Chris
yup, its still there, no idea what ratio tho...
86-surf wrote:Do you that the regulator for the rear window??, It should be tucked in behind the panel, Just behind the passenger front seat,
Thanks
yep, itl be there, make an offer.
