how difficult is it to bobtail a rangerover
i joined some friends on a dirty weekend and i had a ball but i realised my rangi just can't keep up with the big boys and they are who i want to play with so how do i go about doing a bobtail to a rangerover
i'm thinking of putting a flatdeck on the back and move the petrol tank underneath it and removing as much of the overhang as i can also thinking of shifting the radiator to the rear as well that gives me heaps of room to mount a winch on the front
and most important thing is i want to keep this machine road legal
any suggestions and advice would be apprieciated
;-p
http://www.offroadexpress.co.nz/modules.php?name=Forums&file=viewtopic&t=60
All the info you need starts right here!! - As I recall this was one of the earliest project write-ups on this forum.
If at first you don't succeed .... Get a bigger hammer!!
yeah i checked those threads out last night
i'm thinking of doing a couple of things differently
i'm thinking of removing the whole roof and chopping the middle out and getting it tigged together to make a small roof the main reason for that is it might make it easier to build the rear panel i probably won't bother keeping the original fuel tank though
you know the usual story everyone has different ideas how to do everything i agree with the rivetting thing though and i'm thinking of putting seat belt anchors in so i can change the seats coause my seats are stuffed
who are some decent 4x4 certifiers in the waikato
I've got a chassis & body that have been bobtailed here if your interested. I't's been done as a station wagon. Needs some rust repairs in the usual places - sills. I bought it as a project a while back but have slowly been robbing bits off it for my other trucks
- tomsoffroad
- Flopsie
mercutio
Posted: Fri Oct 28, 2005 7:22 am
thanx
but i already have a rangerover ready for the chop the hassle is though now that i am looking at doing this it means the interior panels i bought to deal to the rust issues i have in the back are surplus to requirements as well as the rear tailgate
bugger
http://www.trademe.co.nz
- tomsoffroad
- Flopsie
i should had gone on a dirty weekend sooner and i might have decided on this solution sooner
i went for a wander around my old mans workshop over the weekend found a good fuel tank i can use which should leave me enough room under the deck to put the spare and if i am lucky an on board air system as well there are some spare air tanks there as well and worst comes to worst i'll put the air tank above the deck and because i hope to have an on board compressor the tank doesn't need to be too big
i'm also thinking of moving the radiator to the back as well leaves lots of room to mount a winch still trying to decide what sort but i might end up going with a hydraulic due to the hassles and price of finding a pto for the rangi gearbox
long term goal would be an air operated fiddle brake system cos my old man has quite a few air solenoids floating around there doing nothing as well as some hydraulic ones which i hope to steal for the winch
so how are my ideas so far good or bad
- eatenfuller
- eatenfuller
eatenfuller wrote::D Half of my roll cage is closed off for the use of air for lockers etc,_and the other half is used for an extra hydraulic reservoir for my winch._I designed this over 4 years ago and had no prob's at all (more oil, less heat!!!!!!)
Not to bad
