can this conversion be done, an is it worth it if i have to buy a motor anyway
it a gen 2 1993 had a 3l v6 auto in it, want to use the same trans and just plug and play with the motor
sam
3.5 v6 into a 3.0l v6 hole?? asap
solves that haha, lucky
in that case....
ANYONE IN THE KNOW OF A MINT 3.0L V6 MOTOR!
027-631-6448, gjboswell@xtra.co.nz or 'pm' me
btw njv6* your a grat help
in that case....
Hey NJV6
There was a GDI 3.5 on trademe last week. I think the guy wanted 4g for it. Auction has now closed. but this is the link:
http://www.trademe.co.nz/Browse/Listing ... =130550297
If it is a head issue check out the question at the bottom.
My motor isnt sounding all that flash. Hopefull the oil change with MBL8 I did at the weekend will help.
NJV6 wrote:How long have you had this vehicle?
The 6G72 3.0V6 from a GTO, Magna or Diamante should fit ok but you need the Pajero bits to bolt over. Such as power steering, inlet manifold, a/c, exhausts etc etc
P.S. I need a 3.5 DOHC motor!
just got a hold of this bad boy, been using the old mans one while i try find one since i sold my car a while back, now my story begins
Maje wrote:Hey NJV6
Sounding flash? As in lifter noise? MBL8 should help that but thats about all....
NJV6 wrote:LOWDWN wrote:just got a hold of this bad boy, been using the old mans one while i try find one since i sold my car a while back, now my story begins
Did you buy a lemon or was it cheap.....
Go on, lead the way.... 1UZ... 1UZ... 1UZ...
you tell me your point of veiw, 1993 4 door v6 auto, blue with 158ks on it, near new 31's (will do for mean time) rear locking diff
$800 rego'd, just needs amotor, the trans is there
1uz ya reckon haha, not sure bout doing another conversion, end up costing twice as much as ecpected even if you add the 50% extra ontop
found a wreckers with the factory 6g72.... but....
they want 1750+gst incl a 90day warrenty, compleate motor minus alt and starter
is this reasonablr or should i get over it and wait for another bargain, v300 motor 595 from a wreckers but im not a fan if trying to soarce the parts i might be missing
http://www.trademe.co.nz/Trade-Me-Motor ... 275526.htm
theres a motor for ya. then sell off bits to recoupe your costs.
look up v3000 on trade me. there will be heaps on there and you get to test drive the mtr so you will know its all good. thats what i would do for a simple option. slightly more complicated option is to get a gto quad cam mtr. again, id try get a damaged car. then there are wiring issues tho, but the mtr should bolt in.
Sam
Sam
