DANGER
gonfellon
DANGER
Post by gonfellon »
between no.1 and no.2 dams at the back of shannon some a..hole has dug 4x4 traps. watch out if any people are planning family trips up there as three kids where in my vechile and my mates rangie which is about 10 meters away in another hole .please watch out as smaller 4x4s would end up on there roofs .lucky one winch in the front and one at the rear was anuff to pull my rangie out
badnuz
Post by badnuz »
strutrh there some idiots out there! how did you end on that angle?
gonfellon
Post by gonfellon »
my friend is in his rangie 10 meters away in the same position .someone has dug holes that u cant see until it too late
DaveM
Post by DaveM »
Is there an actual road leading to that?
If not, just make a new track more to the right if possible?
gonfellon
Post by gonfellon »
yes there is two tracks one i took and 1 my friend took ill up load a pic from behind the tracks are well used the holes you cant see as they are only 1.5 mtrs out and the same deep .and 3mtrs wide the spade marks are still there
DaveM
Post by DaveM »
gonfellon wrote:yes there is two tracks one i took and 1 my friend took ill up load a pic from behind the tracks are well used the holes you cant see as they are only 1.5 mtrs out and the same deep .and 3mtrs wide the spade marks are still there
Only reason I ask if it was a track, is that if is well used it may be easier to start a new track slightly to the side so no one else ends up in there
gonfellon
Post by gonfellon »
made new track on the way out .now there is three tracks but most people will stay on the tracks most used .i would say the person who has done it will do the same to that track aswell
mike
Last minute Mike
Post by mike »
Well if they do it to the other one, someone rolls and someone dies then the police will be involved and a man slaughter / murder charge will be on the cards. Only then I suppose will they realise that what they did was out right dangerous and stupid.
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
I have some good contacts to follow this up with if you want ...can you PM me some more details exactly where it is and your contact details and I will follow this up with the appropiate people which may include the police....can't have that sh#t going on....
dazza85
Post by dazza85 »
Is it posable to to fill these in rather that making a new track ???
What did they do with the dirt they dug out ??
gonfellon
Re: DANGER
Post by gonfellon »
no that road is locked due to logging at moment we use to have permission to drive and hunt through out that area.the traps are before the top dam no.1 ,there is a bridge on main dam road which has a lot of glow worms there .the track is about 5 meters past the bridge on your left that leads down to the river. There is a sign stating that river may rise without warning, its public access to river.
Return to “Planning a trip?”
