73 cruiser bronco
speedfreak
Stropper
73 cruiser bronco
Post by speedfreak »
hey there, im looking at getting into 4wding and have found a truck im looking at, a 73 land cruiser with bronco running gear(302 with a C4 auto box) in it
it is a bit of a project needs couple panels fixed for wof but has a deceleration so its all sweet there.
just wondering if this is a good truck combo and what sorta mileage to expect out of it on and off road? it does have an LPG conversion if that helps but also can run on petrol.
any thoughts?
eatenfuller
Post by eatenfuller »
you cant beat lpg offroad mate (100% dedecated )but 50/50 should be good if its tuned to spec.
what sort off diffs has it got :?: sounds like a cool project :D its good to be different than everyone else :D
also the c4 and the v8 is the best combo offroad ,no worrying about missing gear changes,no stalling ,nothing but 2 hands on the wheel and heaps of the right foot. :D :D
and if its a bronco running gear you wont have cvs to break :D but it will prob have a crap steering lock because of the knuckles but nothing a bit of maching wont fix
speedfreak
Stropper
umm im not sure if the diffs and stuff are bronco or if just the engine/box are will have to find out, will the diffs from a 73 cruiser handle a 302?
yea being different is what its all about, im glad to finally hear someone say its a good idea, i havent met neone that thinks it will be yet...
eatenfuller
:D yes the early cruiser diffs would work :wink: .........but id be more incline to use the full floating type (mid 80s)there alot more less hassles when you snap a diff etc ............but if you drive gently use shouldent have a prob with early fine slpine cruiser diffs :D
dont know about youre bronco ,but you want to take into consideration that the cruiser rear diff is not central (like a hilux etc)what transfer case you want to use with youre c4??
happy fiddling :D
speedfreak
Stropper
hey there
how hard is it to swap to the later model cruiser diff setup? would that have to be certed
im not sure what sort of transfer box etc were used as everything is in the truck atm and is decleared for it.
what transfer case would be suitable? as i said in the first post im new to 4wding so dont know much bout the stuff.
thanks again :>
eatenfuller
:lol: no cert needed for the late full floating type the complete diff and housing will bolt straight under youre leafs (no cert needed)the people wouldent even know unless there into 4wds but even thats not an issue :D
there was one on trademe for, i think 300 ish which is a fearly good price :D (complete unit)
if it was me id use the std cruiser transcase ,this giving you a nice line up with youre rear diff (there offset remember not central)and by using cruiser you can run a pto winch cos all cruisers have the pto outputs on all transfers :D and well priced and no crap electrics :!:
hope this helps 8)
speedfreak
Stropper
o yea that sounds good, and the pto winch sounds like the way to go from people ive talked to so that transfer box would be the way to go too probably.
how much is a 73 cruiser worth, i mean its very rough and needs engine work and rust cut out of it, SWB. just a ballpark figure to work off would be handy :>
eatenfuller
:D a cruiser that age (not a high demand)stabbing in the dark prob $1000.00-1500.00 :?:
