Cheers scott
Supra missing at high rev's
Help, my 1ggeu[2ltr tiwn cam] has got a bad miss at high rpm
.I've replaced leads,coil etc,computer.Any thing that can be unpluged and swapped has been
.I'm getting a bit pissed off with it
any idea's
.Seems to get worse as it gets hotter ,i may have to resort to using a box of matches
Cheers scott
Cheers scott
- overcast_nz
- Winch master
I know this mite get me in trouble, but I'd head over to http://forums.toyspeed.org.nz/ and ask there
- eatenfuller
HMMMMMMMMMMMMMMM hotter it gets worser it goes,
you say youve swapped and checked things..................were those new leads ,NEW,NEW????(im thinking its resistance the number 1 player with heat)im going to rattle the crap out of you with questions mate
dont stress scott well have it sorted before ya know it
- eatenfuller
any help would be much appreciated
its in a surf too.
dont wana hyjack the post but its just recalled my memory
- eatenfuller
any way possible to get the contact of the guy who wired it up???????
thanks for ya help scott.cheers
oh and scott with youre truck.............did you replace the leads with a NEW set
- tomsoffroad
- Flopsie
Hows't you lot, got it sorted
,I think
.Replaced the injectors
and took it for a run down the road[bonnet latched down this time]it revs nicely to 7500rpm and 8000rpm doing donnuts with no sign of the rev limter
Heading out on a run with taupo club this weekend
.I'll let you lot know if it still going all right.
Is it possible to put wiring daiagrams on this web site
Cheers scott
Cheers scott
- eatenfuller
- eatenfuller
the guy who wants the diagram is living up in wgtn for the next 3 months finishing his trade cert.................................ive got his mobile number so il call him today for details on a mailing address in wgtn
thanks pinky much appreciated
- tomsoffroad
- Flopsie
Did you do the base timing?
There is a yellow plug with a black rubber cap and two wires going into it. The plug is located beside the coil somewhere. Take the positive off the battery. Bridge the two wires in the yellow plug and reconnect the battery, then unbridge the two wires.
If you don't do this then your engine will run at 15deg advance reguardless of what revs the engine is doing. Because it will be in limp mode!!!
