KZJ Prado suspension arm bushes
IcedJohnno
Trailer Trash
Post by IcedJohnno »
Hi All
My truck needs the radius arm bushes replacing in the rear where the arms connect to the diff housing.
Having read about these for the Nissans where everybody recommends factory bushes I thought I would ask Toyota.
Seems they only supply the front and 1st of the rear bushes but you can't get the rear bush, its not replaceable!
Also the prices were horrendous $114 & $138 + gst respectively EACH. :shock: :shock:
Can anybody suggest good quality bushes that will last well and will actually flex?
HELP thanks :)
Johnno
Re: KZJ Prado suspension arm bushes
BNT?
krawlr
Post by krawlr »
you can use 80 bushes ... i got some for my prado chassis build up & is all i can say is they are blue :P & i think they were from bnt?
IcedJohnno
Trailer Trash
Thanks guys
Are the bushes the same part for all three positions or do they differ for all ?
I want to get the parts all sorted before I take the vehicle off the road this time :roll:
How have the after market parts worked for you Krawlr, plenty of flex and durability?
krawlr
Post by krawlr »
have fitted 80 castor bushes & new on the rear but not at the chassis link ends....got them off warren @ 4wd bits.
yep seem to flex fine,would of done 6k on them already...
any more queries ring mike or grant @ g.guy motors bud
SupraLux
Complete Bastard
Post by SupraLux »
The blue BNT "Noltec" bushes have a reputation for being quite hard - if you are going to go urethane then have a look at the Nolathane range, as the quality of the urethane is better, and more supple.
Don't expect them to be cheap tho... If they are anything like the Nissan ones you will be doing overtime to pay for them :)
Steve
Return to “Toyota”
