Crude, but it worked
The first is with the rear sway bar attached
The next is with Rear sway bar removed!
What do you think?
Remove it?
Same!
Elmo wrote:I havent done a true test yet, I had to reconect it to drive home (otherwise it would flop round)
I will remove it. I had already done so at the front and noticed no great difference. Im going to take rear right off and give that a go.
