1 got the diff fitted up on the bolts but would not slide into diff housing.
2 tryed to get the locking ring to slide into locked diff. BIG PROBLEM . the ring gear didnt move.
3 took the motor off and tested it. no go, took old motor off my old diff and placed it on new diff. still no go
4 found the gearing for the diff lock was stiff so i worked it a little and added some oil to help. Hay it working better
5 tryed getting diff up again ( getting tierd ) took three goes to get it there. slid into place with eassss.
6 started with left side drive shaft ( long shaft ) couldnt get the cv to hook up on drive shaft.left it were it was
7 started on right side got i all together
8 got the left side together
9 drive shaft on and then greased up those kuckles.
10 it's getting to dack to put on tires
Sunday
Fill diff up with oil
fitt tires
test drive
Oo one unhappy wife sent to long on the truck
