1985 Toyota BJ73 Landcruiser FOR SALE
FRP (fibre reinforced plastic) removeable roof/fold down windscreen etc
3.4L diesel (3B-II engine), 5 speed manual
Snorkel
AISIN free-wheeling hubs
33/12.5/15 Maxxis Buckshot mud tyres on white steel rims
Rocksliders
Rated recovery hooks front and rear
Diff breathers extended into cabin
Since purchasing 6 months ago I have:
Replaced injector pump top seals
Flushed coolant, replaced thermostat and rad cap, aftermarket temperature gauge installed
Replaced air and fuel filters, changed fluid in both diffs
Changed engine oil and filter every 5000km as required
New headlight housings and 70/75W lamps
New windscreen
Replaced pitman arm ball joint
The previous owner advised this truck uses no oil or water - which I have found to be the case. I had the compression checked when I bought the truck and all cylinders were within spec. (410psi-420psi from memory). Body condition is average though no rust to speak of. Needs LR axle seal replaced.
Nearly forgot, truck has done 176000 kms
Offers over $4000 welcome. Truck will be in Queenstown until ~10th Feb then Dunedin.
I'll take more pics for those that want them.
