I'm wanting to move my engine back 80mm to 100mm in my rally truck, the current layout is a 3sge attached to a w50 steel case 5 speed, short drive shaft then a transfer case from a 410 flatdeck, I think the low ratio is around 2.5, diff ratios are 4.8's (hilux) and 33" tyres.
I want increase the clearance between the sump bowl and front axle, also align the mounts on the engine, and get the weight off the front a bit more.
Later on I intend to replace the 3sge with a 3agte going from 186Nm to 304Nm and fit some 35's but that is a wee way off, so I want something which can take the abuse.
I want to keep the same transfer ratio or lower, as it is good at the moment.
So my questions is what transmissions choices are there that might suite?
Chris
