Spark Arresters Mesh Wtd
Dick
Post by Dick »
Hey Guys,
As i now have a 2.5in strait pipe in my truck, with no mufflers at all, i think i need a spark arrester for the bush runs.
Would anyone know where you can buy the fine steel mesh or gauze that is suitable?
Dick
Go Hard or Go Home
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Pretty sure Ive seen cooking Sifts (sp?) in places like $2 shop or even The Warehouse. Should do the trick??
lilpigzuk
Tiger Balm
Post by lilpigzuk »
this sort of thing, then just hoseclamp it too exhaust
turoa
Pyro Junior
Post by turoa »
you might need a bigger exhaust though :lol:
Baldrick
Post by Baldrick »
lilpigzuk wrote:this sort of thing, then just hoseclamp it too exhaust
You been hunting thru mum's cooking cupboard again for parts :?: :shock: :happyjump:
Baldrick
91 Cruiser VX Ltd Auto Diesel Turbo *Safari snorkel * 80mm RAW suspension lift * Custom Bull-bar * 33" MT tyres * 26Mhz & UHF CB units * West Coast Rust * And a partridge in a pear tree! Oh... and an awesome new Co-Pilot :mrgreen:
lilpigzuk
Tiger Balm
Post by lilpigzuk »
all farkin comedians arent ya's Image
Baldrick
Post by Baldrick »
Just trying to think how the handle bit attaches to the exhaust pipe :?:
Zuks were always an odd buggy :joker: :P
Baldrick
TJ
Post by TJ »
Just use it as the hangar for the last bit of the exhaust (i.e. the exhaust clamp) :roll:
Dick
Post by Dick »
Thats perfect. Thanks. will get me one tomoro.
Your exhaust can never be toooo big.
8)
Cheers mate.
Go Hard or Go Home
Baldrick
Post by Baldrick »
Here's the piccies of one I made from a sheet of guaze/mesh....similar to what Lilpigzuk has alluded too. It fits over the end of my exhaust which is nearly 3" at the end. :D
I guess it would be a good idea to tack/spot weld the end fold, but this has lasted me 4 years now. One day I might get around to sealing the end shut properly, rather than just folding it.
Finished length is 7" long. Sheet was 10" wide to start with. Hope this helps. :D
Baldrick
Dick
Post by Dick »
Baldrick wrote:Here's the piccies of one I made from a sheet of guaze/mesh....similar to what Lilpigzuk has alluded too. It fits over the end of my exhaust which is nearly 3" at the end. :D
Cheers mate.
Go Hard or Go Home
SMOKEY
Post by SMOKEY »
Just pull a strand out of the cut edge of the mesh and use it as a piece of cotton to sew the sock up :wink: .
EASY AS,
FITZY.
Swaney
Post by Swaney »
Outta interest who has and uses a spark arrester?
I guess we should all use them over summer if we are on dry / dusty land??
Can someone school me.
Thanks
IcedJohnno
Trailer Trash
Post by IcedJohnno »
I use one on my turboed Prado, have done since I bought it.
Why? I drive up in the high country a lot over summer and don't want to have to foot the bill for a DoC and Helo driven fire fighting session!
Having said that, others have said on here that turboed vehicles don't need spark arrestors. What is the informed reasoning behind this?
cheers John
fweddy
Post by fweddy »
IcedJohnno wrote:Having said that, others have said on here that turboed vehicles don't need spark arrestors. What is the informed reasoning behind this?
I figure that the spark arrestor catches any sparks from the engine by very simply giving it something to hit to interfere with its path and therefore extinguish it.
A turbo is also in the exhaust line and so is basically doing the same thing.
That's my uneducated, unproven and therefore worthless logic.
UBZ
Post by UBZ »
Wouldn't a Catalytic converter have the same effect?
It is in the exhaust line as well. (If you haven't ripped it out :twisted: :twisted: )
TJ
Post by TJ »
Spark arrestor - normally needed on diesel vehicles only.
Catalyst convertor - normally found on petrol vehicles only.
Having said that, catalyst convertors do get hot enough to cause/start a fire if they come in direct contact with dry vegetation (over a period of time). Best example would be when a petrol vehicle is parked in tall dry grassy area, be prepared for a BBQ.
Baldrick
Post by Baldrick »
Not just sparks...but the very hot little particles of soot and "crap" that gets spat out the rear end of a deisel exhaust.
Many forestry areas wont let deisels in without one on in the summer, and even high country stations - ie Molesworth - due to the VERY HIGH & real fire risk.
I leave mine on all summer, and just give it a clean out if dirty or muddy with a stiff brush
Baldrick
4wdnuts
Post by 4wdnuts »
i go into forests all year round. it is mandatory to have one on a non turbo diesel.
Swaney
Post by Swaney »
Just to clear something up...
Turbos do not need them as the turbo spools from exhaust (therefore collecting and the crap / sparks and pushing them back through the engine?)
Is that right
Or am I out chopping up the misses kitchen tools later on tonight?
wopass
Post by wopass »
get a couple of steelo pads and bung them up the tail pipe,then drill a couple holes just before the end of the pipe and put a couple of long M4 bolts thru it,one virticle and one horizontal to stop the steelos from comming out,works a treat to shut up noisey zausts and acts as a spark arrestor as well. :wink:
NJV6
Post by NJV6 »
Swaney wrote:Just to clear something up...
Is that right
Turbo's don't send the crap/sparks back through the engine, its exhaust gasses spin the turbo, then goes out the exhaust.
Swaney
Post by Swaney »
Is that right
Good call
Now I see it written down I feel quite stupid :D
newbe
Newbie
Newbie
Re: Spark Arresters Mesh Wtd
Post by newbe »
Question. Will a kitchen seive pass as a spark arrester on a comunity run 4wd trip in the Hurunui? Cheers.
Dick
Post by Dick »
newbe wrote:Question. Will a kitchen seive pass as a spark arrester on a comunity run 4wd trip in the Hurunui? Cheers.
My one is a makeshift warehouse sieve that has been layered a few times. Best to talk to who is organising the trip as to whether it is up to standard though.
Go Hard or Go Home
kiwipete
Post by kiwipete »
Yes, mine has lasted twice as long as a std gauze one, but then I bought a stainess steel one feom the whouse for 5 bucks.
Ph 0212078472
Return to “Tool Shed”
