Hilux diff head, or diff parts needed ASAP
hosehustler
Post by hosehustler »
Hi all,
I need a diff or 2, whatever you've got 4.3, 4.5, or 4.8, doesn't matter as i'm rebuiling with TG 5.29 R&P's, even a stuffed diff will be fine as long as it's one of those listed ratio's :wink:
I'm supposed to be hitting the rocks next weekend and unless i get a third member or housing soon i'll be struggling, so please if you have something that you think may do the job, post here and i'll contact ya :mrgreen:
I hate signatures
muddy_munke
Re: Hilux diff head, or diff parts needed ASAP
Post by muddy_munke »
I have a 4.3 sitting in my garage. Needs a pinion seal and a rebuild.
Would suit you perfectly...
Let us know. Cheers Daniel
Smurf
Post by Smurf »
Bugger i thought you had your diffs sorted. I have a stuffed 4.5 here in Nelson you can have if you want, just need a cheap way to get it to you.
hosehustler
muddy_munke wrote:I have a 4.3 sitting in my garage. Needs a pinion seal and a rebuild.
I'll take it off your hands, sounds perfect :wink:
0272074454
Tim
I hate signatures
hosehustler
Smurf wrote:Bugger i thought you had your diffs sorted. I have a stuffed 4.5 here in Nelson you can have if you want, just need a cheap way to get it to you.
Yeah sounds perfect as well.
Bits for you are all here ready to send, any freight company you'd prefer :?:
I hate signatures
Smurf
Post by Smurf »
One that gets the bits here... cheers
NJust who ever you would normally use.
I'll see if I can sort a cheap way to get diff head to you. Freight companies expect about $40-50 bucks.
nstg8a
Post by nstg8a »
Il be pulling the last of the bits of my parts surf tomorrow if you need anything keith, im not taking bugger all, and the rest will be going to the scrap yard....
flick me a txt, 0277490350
