has anyone ever had a terrano g/box rebuilt????
how much would this cost, depending on the damage i guess!
it still drives fine just sounds like a few rough bearings, in 2nd and 3rd!
terrano 5-speed re-build??????
D21 terrano, v-30, 5-speed, 2" body lift, 2" suspension lift,
custom idler arm brace, still working on the bars.
Re: terrano 5-speed re-build??????
Get it done asap. Not sure if the V6 ones are the same as the diesel ones but get it done before it totally $%^Y's its self.
If its just bearings you might get away with about $1000 if not $1500+ (if you pull it and put it back yourself. the manuals in the terrano's are weak.
I had mine done twice. First time badly. When it was done second time round the guy that did it found nissan factory bearings in it still
mine went (deisel manual) in november and cost $1200 (roughly) - with a trade through a company in palmerston north.
I had mine done after I stripped first gear. Literally. I pulled it and put it back in and that cost just under $1500 about 7 years ago.
Rember the filler plug has been cast to low in the gearbox so when re filling top it up through the gear lever hole.
Ive got the info here with exploded diragrams ifn u are goint to rebuild it yourself.
hey some diagrams would be awesome, as i will be doing it myself!
No probs come back with an e mail addy so i can get them to you
Gary
Gary
jarrad_williamson@hotmail.com
have been looking at the forum, do u still have the manual on cd??
if so how much for one?
thanks heaps, i really appreciate it, infoabout the gear lever was good too,
cheers jarrad
cheers jarrad
i can get gearbox bearing kits for this model $160+gst
my terrano has a nosie box but I managed to buy a rolled terrano with good 5 speed box for $150. So im not to worried about mine at the moment
hi all, just wondering if i could get those diargrams sent to me aswell please "long" can get me at skid4x4@hotmail.com
also "madterrano" where abouts in the country are you, if youd be keen to hook us up with a kit?? im in chch, im probly going to do the heavy duty front bearing but the rest will still be good to dowhen its out,, and the best ive found is 300... drop me a line on the above adress if your keen, cheers skid
