how do i figure out my diff ratio???
d21
Post by d21 »
hey guys, i have a set of hilux diffs for sale, people keep asking me what ratio they are.
i know i need to mark the input and hub, and turn the input untill the hub has done a full revolution, while counting how many times the input has turned!
and i then have to divide or multiply????? im stuck on this bit any help would be grate!
D21 terrano, v-30, 5-speed, 2" body lift, 2" suspension lift,
custom idler arm brace, still working on the bars.
Cloggy_NZ
Texas Chainsaw
Re: how do i figure out my diff ratio???
Post by Cloggy_NZ »
Count the teeth on the crownwheel and count the teeth on the pinion.
Divide the crownwheel teeth by the pinion teeth and that is your diff ratio.
Return to “Toyota”
