Show us your Nissan
For all Nissan related topics
Frugil
Post by Frugil »
Hi all, started as this without the snorkel.....
Now it looks a bit more like this.....
Today it looked like this
Since I've had it (quite a few years now) I have replaced the clutch, every bush in the bloody thing, bearings, Shocks and rear springs (50mm lift), 55mm body lift, Big wod of steel to save my poor truck body, stripped out anything that wasn't really required inside, removed aircon system (taking up unnecessary space :lol: ) Steel rims and 31" mud tyres Had to lift the suspension and the body so that I can get the 33" muddies on. (Tried a mates set on the other day and the fit!) Essentially my body is now about 125mm higher than it was when I bought it. (spring sag etc)
Also, lifted the body right of my truck for 3 months a year ago, mainly for fun but it is quite easy to change the clutch with no body in the way, also suspension and bushes become very easy as well.
All I can think of at this stage.
Ken
gary_in_nz
nisbro
Post by gary_in_nz »
i guess i had better do the honourable thing as well and put up my new toy. Had it about 2 weeks, already got 2" springs on the way and i have my 33"s ready to go on, snorkel is about to be ordered once this weeks pay comes through. has lsd and a warn winch 8000lb, air con that works, a crap radio that only plays tapes. 4.2L non turbo, has plenty of grunt for a non turbo i was very suprised, lots of torque!!! does mean doughey's too!!!
better offroad machine than my landrover, and parts are plentyfull and not too expensive.
Standard
Standard
After 50mm springs and 33" tyres, had a bit of a play
catcha later
philbell
Stropper
TD2.7 Nissan pathfinder
Post by philbell »
canon 11,10,07 054
SV1K
Site Admin
Post by SV1K »
This is what it looked like half was through the first trip Image
I will up load more soon of what it looks like now....
Allan
Post by Allan »
Taz
Post by Taz »
Thought I might as well post a pic of my Safari. Won't bother with general shots as its nothing different from the usual.
Heres the back.
krawlr
Post by krawlr »
gona take a bit to beat doddzees cool trayback :thumright:
darinz
Post by darinz »
Sorta like Dodzees but with a wee bit more power!!!!!
Shane
Re:
Post by Shane »
darinz wrote:Sorta like Dodzees but with a wee bit more power!!!!!
Nice 8) Have you got the Twin turbo set up sorted?be quite a lot of tuning for that sort of set up,not really run of the mill trans plant....
Can you give it the jandle with out popping shit?its a MWB correct what does it measure?
Cheers Shane
You should do a run down the 1/4 mile strip with some road tyres on :D
darinz
Re: Show us your Nissan
Post by darinz »
It has a single T04z and an Autronic ecu and cdi ingition. There's a fair bit of tuning left to be done, ie still restricted to 6000rpm and not using the VVT so once fully tuned we're expecting over 300rwkw so will be up the top Oz trucks in the hp stakes.
Also I've fitted an Extreme Manual valve body (from Oz) so it is a manual auto. The drive train except for the hubs/CV's is plenty strong enough. I'm thinking about cro-moly CV and drive flanges as I'm currently eating freewheel hubs.
Wheel base is 104" but with the power it has I'm thinking of going a little bit more. 106-7 seems to be the favoured length for highspeed driving. It is such a handful at high revs, I need all the help I can get!!!!!
Shane
Post by Shane »
do you think it has lost much weight over the td42 engine,the diesel is quite a heavy unit must have lost a bit?
Does a EXO cage pass as a roll cage in the winch challange rules?
GQTROL
Post by GQTROL »
Shane wrote:do you think it has lost much weight over the td42 engine,the diesel is quite a heavy unit must have lost a bit?
TD42 weighs 350kg with all accessories, VH45 weighs 270kg in same state, so 80kg saving.
darinz
Post by darinz »
The VH is close to 220kgs including starter, alternator etc so more like 130kgs saving. Cylinder 3&4 are above front axle so weight is also further back so all up the front axle is carrying a lot less weight. It is going on the scales soon so will know for sure then but it appears to be close to 50% front and rear now!
Exo cage is fine. Most new truck being built are running an exo but I'm going to fit an internal as due to wanting to do higher speed events and this is one very fast truck in a straight line!
GQTROL
Post by GQTROL »
darinz wrote:The VH is close to 220kgs including starter, alternator etc so more like 130kgs saving.
You sure about that Darin? Mate was going to do the VH45 conversion, bought the engine and weighed it (certified scale). It was 600lb (270kg) on the dot, with all access. He sold it and went for something else instead.
darinz
Post by darinz »
478lbs (217kg) without alternator, PS, starter etc, with exhuast manifolds but they are tube so not much anyway. This is on a crane scale and I've seen the photo. 600lbs would include the auto as that is around 90lbs. The VH is lighter than an RB26DETT motor!
While the VH is heavier than an LS1 (due to quad cams) it is still an all alloy motor. It is quite possible to drag it around on a concrete floor once bolted to auto and trasfer case, and while I'm a big guy, I can't see any way I could drag around about 400kgs!
d21
Post by d21 »
only had it a week, body lift is in, alredy had lifted springs in the rear, had to take out the
torsion bars and reset them and wind them up.
still a lot of work to do.
D21 terrano, v-30, 5-speed, 2" body lift, 2" suspension lift,
custom idler arm brace, still working on the bars.
gary_in_nz
time to trime those guards a bit any fit some 33's :twisted: is it the v6 petrol or the turbo diesel??
d21
Post by d21 »
yeah im trying to swap some hilux diffs for a set of 33's but no luck so far!
its the v-30 petrol, not sure how happy i am about it tho, im use to running a diesel l200!!!
Ryan
Post by Ryan »
d21 wrote:yeah im trying to swap some hilux diffs for a set of 33's but no luck so far!
lol i have a V6 petrol terrano and know what you are saying......very thirsty arnt they!!!
d21
Post by d21 »
just a tad!!!!!!
long
Post by long »
ahhhhhhhhhhhhhhh the joys of owning a diesel huh guys my Kyron gets over 800 ks to a tank full of the stuff havnt done a check on the terrano yet
long
Post by long »
sorta done a check now on the terrano from Huntly to Inglewood in the Naki $28.00 for diesel
d21
Post by d21 »
thats just wrong!!!!!!!
although mine is a bit better on gas now ive done the coil, leads, dizzy cap, rotor and some new plugs!!!
got a bit of work done, bar work still needs finishing, sliders and bash plate still to go on.
done anything to yours yet???
RJT
Post by RJT »
Well after ditching the bighorn mid last year, have finally bought new toy. Got this a couple of weeks ago, already had 2" suspension lift and 30" all terrains, chucked on a snorkel and went n had a play at the waimak... Pics are off a phone so are pretty bad quality.
Wheel in the air
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
long
Post by long »
Ok done a fuel check over easter weekend the Terrano is useing 8.2 ltrs per 100ks not bad for a 1990 shitter huh
3VILC
Post by 3VILC »
This is my Saf when i first got it about a month ago
This is it as it pretty much is at the moment (except its had a wash since this pic lol)
Bodylift is en route, and waiting for my snorkel on the next shipment from TJM. Still debating winch ideas in my head lol
safaripete
Post by safaripete »
brought this in january 07 as a bog standard GQ LWB to tow my minisprint round for 800 bucks :D
on 31 ats
pto winch (now cleaned and working awesome)
now has a 65mm spring lift
recovery hooks
32x11.5x15 bridgestone MT
snorkel
removed front bumpers (got sick of pulling them out)
list of future mods
35x12.x15 simex
home made winch bar with side step protectors arb copy hopefully :?
50mm body lift (this week)
storage in the back for all gear and fridge etc
will put up pics when i have done more
hope you guys like
Mad Matai
Post by Mad Matai »
Bye
contour
Post by contour »
all the mods done are.
50mm body lift
100mm suspension lift
35/11.5/15 Simex ET2
Wellside ute chop
Front and Rear guards chopped for tyre clearance
Rear sils chopped
Rock sliders
Rear LSD diff
Still to come.
Roll bar
Spot lights
custom front and rear bars
long
Post by long »
looking good dude
Return to “Nissan”
