Some sick thinking on IFS
MATT4U
Post by MATT4U »
With longer arms and re mounted bumpstops it will
De-Ranged
Post by De-Ranged »
center mounting the diff head and using that extra length in the swing arm and axle .... dosn't increase the cv angle range but it does increase the length of the arm and the distance the wheel has to move.
Means custom axle, made to use your current CV's & tripod joints,custom extended swingarms (possibly steering as well uncertain at this stage) and with the pajero reuse the current torsen bars or insert a coil spring (not certain on surf .... if I can reuse torsen bars :scratch: )
and if you want I can build it with a wider wheel base giving more travel :twisted: just mean you'll need spacers for the rear axle :roll: and flairs
Cheers Reece
SupraLux
Complete Bastard
Post by SupraLux »
With the torsion bars you might not have enough travel due to them unwinding before they fully droop on your long travel system... might have to go to a coil-over similar to the new Hilux front end has...
Will it not annoy you having a front end that looks like the back end of a RAV4? :) (ie: the perfect shape if all you drive over is big trangular bumps :P)
Steve
De-Ranged
Post by De-Ranged »
:lol: I don't think it'll look anything like a Rav's spindly little arms, I'm still over engineering things :wink: its so much easyer to weld 6mm wall pipe than 2mm tube :P
Not to mention there swing arm is to bloody low!! what a waste of clearance :twisted: as for your triangle... it'd be a bigger triangle than your beam axles will manage :P
And the coil over is the better option just means a new strut tower might manage to sort something that bolts into whats there hmmm haven't looked much at the spring options it wasn't really a limiting factor
Cheers Reece
matwelli
Post by matwelli »
Good work Reece, you sound disapointed with 12 inches of travel, but its 6-7 inches more than the manufacturer gave us, keen to see some pics/ideas for the paj front end.
Cant see a prob with the torsion bars unwinding, as (I guess) the a-arms will be travelling thru the same arc as standard, but the increaded travel comes from them being longer ?
Can always use air shocks to suplement them anyway.
Like the air ram Idea, on the road you could cross couple them (top left to bottom right, top right to bottem left chamber) to act as a sway bar.
Mathew - 021 441 043
tristanp
Post by tristanp »
http://overkilleng.com/
have adifferent approach you might want to look at
ive got a 4 page magazine article i could upload if you wanted any further info
