What rear shocks fit 91 2door vitara?
For all Suzuki related topics
hitbiga
Post by hitbiga »
hey there, just bought some 2" coil spacers for the vitara,doing a strut flip on the front but need to find some longer travel rear shocks, anyone out there know of what rear shocks would fit, out of what car? pics would be good.
also would longer springs out of another car benefit over coil spacers, im thinking coil spacers would decrease travel?? any help would be great :lol:
spanky
Re: What rear shocks fit 91 2door vitara?
Post by spanky »
search (cheap vitara lift)and have a look there.this can be achevied (good spelling) for very little money and gives about 65 to 70mm as well as good travel, any queries give me pm.
vaughan
icekayak
Post by icekayak »
Hey
As spanky said try a search :)
Just fit the lift etc in and then measure the rear to see how long/short the shocks can be and then look through trademe/supercheap catalogue etc to find ones appropiate length etc :) From memory some out of a commordore, corolla, etc etc... you want one out of something lightish rather than something big and heavy :D
Just out of interest where did you get the coil spacers from (and if you don't mind saying what did they cost you). I know there is always someone looking for them from time to time.
hitbiga
Post by hitbiga »
ok saw ur post, so e30 318 bmw shocks work, and what year corolla ones?? got the 2" lift coil spcers from this place off ebay, was $150 nz$ landed in NZ as nz dollar is pretty good i can give you the site if you want.
tara13
Post by tara13 »
I put vn commodore springs in front and in stead of a strut flip put 40 mm spacers on top of strut then put 93 honda accord springs in rear with commodore shocks has made a big difference in articulation also took out front sway bar.
allmud
Post by allmud »
in my 93 3door ive done 40mill spacers and used toyota hiace van shocks in the back
and in my 96 ive done 60mill spacers and used vs(96) holden commodore shocks in that
hitbiga
Post by hitbiga »
anyone know if vl rear shocks would work in the back? or vl springs for the front?
icekayak
Post by icekayak »
No, but have a look to see if the shocks have the same fitting as suzuki (ie think its eye-pin but i can't remember)
Once you have lifted your suzuki measure the height where the shock would go compressed/extended and find a shock to suit or measure the vl ones to see if their similar length :) then just fit them and make sure spring won't fall out at full droop and their not too hard/soft :)
Weasel
Post by Weasel »
If you cant be bothered goin round all wreckers etc try BNT as I got new Gabriel front struts for my Scud for $80ea, just give em the type of mount on each end and length you need them to compress and extend to and they'll prob have something.
spanky
Post by spanky »
c33 laurel springs with vl commodore air shocks in the back and ea falcon springs with 2.25 coils cut off and a strut mount flip is all i did to mine and gives so much rear wheel travel you have to put 5dr handbrake cables in to stop them pulling tight and buggering the rear brakes.if you go for more lift you will start snapping cvs all the time.
vaughan
icekayak
Post by icekayak »
spanky wrote:c33 laurel springs with vl commodore air shocks in the back and ea falcon springs with 2.25 coils cut off and a strut mount flip is all i did to mine and gives so much rear wheel travel you have to put 5dr handbrake cables in to stop them pulling tight and buggering the rear brakes.if you go for more lift you will start snapping cvs all the time.
vaughan
Just thought i'd mention that if you want to keep yours road legal then my understanding is you are not allowed to cut the springs. I believe putting in lifted springs and shocks is fine as long as the springs do not fall out at full droop and you retain the factory mounting points or something along those lines, so not sure about coil spacers but i know lots of people that get away with them (similar to the 5% tyre size thing)...
hitbiga
Post by hitbiga »
ok cheers, just got some e30 bmw rear shocks and honda torneo springs in the rear now, gives abit of lift and more articulation, will try look for some springs for the front soon.
icekayak
Post by icekayak »
Did you measure it befoer and after too see how much it gave you? :)
hitbiga
Post by hitbiga »
about an inch lift and 2" more downtravel. :lol:
Dutch89
Post by Dutch89 »
Is there any special tools i need to removed and replace rear coils - or will they just drop out like the front. And do i need an axel puller to remove axels from rear diff so i can fit my diff locker!
Cheers :?:
Weasel
Post by Weasel »
Dunno bout axle puller (and manual is alllllll the way out in garage to have a look in) but taking coils out of rear is simply matter of undoing the shocks both sides and then pushing one side up with jack will help force other side down and coil will drop out.
spanky
Post by spanky »
any slide hammer will get your axles out, easy to do your coils while you are pulling the diff out, put some stands under the chassis rails , put the jack under the diff head and take the weight undo shocks and lower the jack and your springs will fall out.extend your diff breather while your under there.
vaughan
Dutch89
Post by Dutch89 »
Ok i have the front coils done and im impressed, got the tape measure out before i started and the Coby coils gave me a good 2" lift. Im hindsight the 5 door coils were a waste of money, tophat flip on front shocks was a great idea. Thanks for the help guys.
Will do the rear coils tomorrow seeing i have the day off work, and i may start with the diff locker in the weekend or Monday depending on how i feel and if anyone is going to play in the mud over the weekend. Will try to post some pictures later when i sort Zuk coils and my browser, browser is last on the to do list.
Cheers Hans
Dutch89
VK Commodore air shocks
Post by Dutch89 »
I have done the rear coils and spring today and im very happy with the result. I took onboard what all you guys have used and asked a shock shop for the sizes of all the ones that people seem to use. What i found is the the std rear shocks are 460 extended and 290 compressed. The VK Commodore air shocks were 517 extended and 307 compressed. the E30 318 BMW were 547 extended and 356 compressed. Tried the EA falcon ones as some one suggested but the mountings were diffrent.
So i went with the VK Commodore air shocks and the Cobra coils with 50mm lift!. and the top hat flip on front shocks with coils from Cobra as well. 45 mm lift on the front and 60mm on the rear. With the 2" body lift i have plenty of clearance to run 31 X 10.5 tyres. Oh and cost was only $200.00 new for both rear shocks.
Hope this helps
Hans
Return to “Suzuki”
