Lucas 4CU ECU
Lucas 4CU ECU
I don't suppose anyone has a sapre Lucas 4CU ECU hanging around have they??
Thanks
John de Burgh
Thanks
John de Burgh
Re: Lucas 4CU ECU
I think 91Rangie has. Mentioned it to me once. Send him a PM. Could be a 4cux though.
Re: Lucas 4CU ECU
PM andic ....he has 50 rovers in parts at his place
, can PM you his email and ph no if you want
Re: Lucas 4CU ECU
Got a Hotwire maybe know where a Lucas one is how much you wanna pay for one?
Re: Lucas 4CU ECU
Jerry wrote:PM andic ....he has 50 rovers in parts at his place, can PM you his email and ph no if you want
That would be great Jerry, sorry about the late reply i have been so busy woth work and courses latley!!
Howz things??
John
-Vehicle: Rangie - 4 Wheels, 3 doors, Engine, Gearbox, other whirly bits, Steering wheel, Radio, Seats, Pedal that makes noise, pedal thats stops it, and pedal that helps stop the crunching noise when using the gear lever.
http://www.feilding4x4.org
Re: Lucas 4CU ECU
Otherwise I could steal the one off Cloggys disco .....
I'm sure he won't notice
Re: Lucas 4CU ECU
Jerry wrote:Otherwise I could steal the one off Cloggys disco .....I'm sure he won't notice
Now theres a nother option!!
Tee hee
Re: Lucas 4CU ECU
He would just assume that it fell off (being a rover
Re: Lucas 4CU ECU
After a bit of tinkering and swapping and moving bits, it lives!!
Re: Lucas 4CU ECU
Just read this....
You cheeky buggers.
Keep your hands of my Rover
Re: Lucas 4CU ECU
Cloggy_NZ wrote:Jerry wrote:Otherwise I could steal the one off Cloggys disco .....I'm sure he won't notice
Just read this....
You cheeky buggers.
It's Ok Clioggy. you can relax, it's all fixed now!!
John
Re: Lucas 4CU ECU
How did that throttle sensor work John?
Re: Lucas 4CU ECU
Works well Paul!! Thanks!! Just changed the plug all the rest is the same.
John
John
