Right I've just thrown up another update
Update Link
little bit of luck I'll have a fair bit more done this weekend
nivaman wrote:Hey Reece do you think you may put some pics up of the g/box to t/case coupling? give me a few ideas on how to mount the 131 Fiat box that will.
Sorry but found it rather hard to see the steering box pic, any chance of another?.
De-Ranged wrote: apparently it takes a month to process
De-Ranged wrote:I can't get confermation from ORE club if my dues are up to date, or even if I'm a memberdosn't help I don't know who to ttalk to in the club
spanky wrote:looking forward to seeing this thing in action as still cant get over how my mates standard shitter goes everywhere on its road tyres,i scored him some 29inch swampers with tubes for 280 second hand but not to sure i want to give them to him as he will probaly show us up,i hope my project progresses this well once i get back into it.
vaughan
nivaman wrote:Reece
I do have a spare steering relay arm housing.
Would be grand to see those pics, you can use spacers on the top of the front springs if you want to raise the vehicle.
De-Ranged wrote:hopefully the springs prove to be saged... yep you read right I want saged springs, the springs in the one I'm working on were re-set is my guess and they were so tight that the top arm was sitting on the bump stop so hard it had compressed it by about 1/2 an inche... thats all well and good if i'm trying to follow in ruts but if I have to do any X-overs I need the flex or the open diffs will stop me
Oh and for A,B,E & F class you can't run spacers in fact no modifications to the suspension
Oh andI've come up with a better design for the steering stops
but I'm not gona worry about that till after easter
I also have a set of standard front springs, sucks to hear about no mods to the suspension but thems the rules i guess.
Do you want to modify the stops or fit another steering box?, how about bracing the area where the steering box bolts to?, would be interested in one of your transfer case mounts if you interested in making another one??.
Will be wanting the t/case to stay in the same place so should be reasonably simple?? have got a picture so will try to post it up.
http://forum.difflock.com/viewtopic.php ... e+mounting
