g13b gti wiring help
For all topics relating to Petrol engines and modificiations.
413leon
Post by 413leon »
have finally got the g13b sitting in my sj413 but progress has come to a hault due to my lack of wiring knowledge i have a whole barina gt loom and computer and was wondering how much this will cost if i take it to the sparky??? or is there anyone who knows how to do it and wants to make some cash . I am in waihi :roll: :roll:
lilpigzuk
Tiger Balm
Re: g13b gti wiring help
Post by lilpigzuk »
how much you got too spend :mrgreen:
Im sure he will pipe up soon, He wired my POS, and its still going. See if he jumps on, has another gti too wire of mine :oops:
413leon
Post by 413leon »
a few hundred, is it a big job? im guessing youre talkink about rotazuk
Rotazuk
Post by Rotazuk »
Yeh I never did hunt out those wiring diagrams . What year is the engine from ? Pre or post 89 . Mk 2 GTI's the ignition was controled buy the computer , post 89 .
If its post 89 there are diagrams on http://www.suzukiinfo.com/ . If its pre I will have to dig out the photo copy I have here somewhere .
I thought you mate was going to wire it up ?
Its not too hard to sort out . The best way to do it is cut all the tape off the loom , the black stuff so all the wires are exposed . You will need to reshape or shorten the loom anyway so you will have to rewind it . Then you will be able to start removing stuff . Basically tape the computer plug down and trace all its wires , when it goes to a dead end see what the conector is and trace back the other wires in the conector ( they will run to things like the fuel pump etc ) .
One thing to think about is the alt , the gti has a ribbed belt so you can't use a 413 one . If you use the gti one they are wired differently to a 413 one ( only two wires and they swap them , go figure ) , I would get a vitara one they are wired the same as a 413 and will be easier to find in the future .
I am a little busy at the moment and have no shed space to wire up a car but if you strip off all the black tape I could possibly strip down the loom to the wires needed to run the engine . You would have to post the loom up and tell me what the ecu number is so I can check I have one here as I would want to test the loom before I sent it back . Then you or a local sparky could wire it into the car .
I am away all April so do not have a lot of time , but it should only take a couple of nights to sort it out . Take a bit to remember it all :) .
Either way let me know if its a mk1 or mk 2 engine and I will try and dig out the wiring diagram for it if its a mk1 . I will scan and e-mail it on monday .
Chris
413leon
Post by 413leon »
Thanks for the info the engine is a mk 1 and my good mate :( is meant to be wiring it but im getting sick of waiting so i decided to make this post.
I will try and track down a vitara alt aswell.
very keen to send the loom up so you can sort through and get rid of the wires i dont need and then just get the sparky to do the rest. Name a price for the job and i could send it up in the next day or so.
cheers leon
Rotazuk
Post by Rotazuk »
How much of a hurry are you in and what would you want done to the loom ? probably not able to do anything till later next week , trying to get my zuk back together .
To get a tidy job the loom needs to be cut and spliced back together , as it heads off into the engine bay from both sides of the car . This is best done on the vehicle when you know were the ecu will sit etc . The other option is I just shorten the loom to the shortest wire and any extra wire you have you will just have to tuck away . The bad news is the crimps I use cost $1:50 each , that soon adds up .
What I could do is just strip the loom out to the esentual wires , label the ones you need to conect to the 413 loom and you can cut and splice the loom when you have it sitting on the truck . You will see what has to come out when you get it back , mid loom there is a great big conector and half the wires get cut out of it , it needs to go . This would be the best option I think .
As I said thou you need to pull off all the loom tape , the black stuff ( crappy job and it takes time ). Everynow and then you wil come across a bit just wrapped around the loom these can stay , they will hold it roughly in place . Also leave any rubber grommets on there , you will feed all the wires through one in the firewall .
If you want to send it up let me know as I will send you my addy .
Chris
413leon
Post by 413leon »
Not in a hurry but really want to get it running as you said strip the loom out to the esentual wires , label the ones I need to conect to the 413 loom.
I think thats the best option.
I will strip all the unneeded tape off tonight, so if you could send your addy to me I could send it on friday and you can do it when you have the time as long as it doesent take weeks lol :D
cheers leon
Rotazuk
Post by Rotazuk »
Got your loom and ecu today . Currently spread out around the lounge . A little ticked off as I have just spent the last couple of hours taking all the black tape off the loom :( :( Grrr , I have a million other things I need to get done , picking tape off your loom is not one of them . Rant over .
Anyway the ecu and loom are from a car without the EGR equipment , ie NZ new I would say . If you have the EGR you may as well block it off . I will strip the loom to EFI stuff only , meaning things like oil pressure and alt wiring will be existing 413 stuff . Most of the sensors are in the same place except for the water temp . Also are you running elec fans ? The last temp sensor on the rear of the engine on the water output is a switch for fans , so you can run them in auto . I will try and locate the plug and label it for you .
Issue could be the points as this is not controled by ecu , again will see what I can find from the loom but can't find the complete wiring diagram , only the ecu part . The loom includes the main relay and the fual pump relay , so you are sweet there . Have you sorted an electric fuel pump ?
Well do a bit more tomorrow night and see how it looks then
Chris
413leon
Post by 413leon »
I didnt realise all the loom that i left with tape on was needed and was just going to get you to label it for me sorry my mistake :x :shock:
I will just go with the original fan for now but if you could label the wire so if i decide to run an electric one later i know where it goes thanks
yes i have the gti fuelpump that i will put in soon
sorry for the tape mix up :) let me know how you get on
thanks
leon
Rotazuk
Post by Rotazuk »
Only about 1/2 hour done tonight . The injector harness is not here :(
I don't need it but you will . The four injectors and the oil pressure wire mearge at the left ( rear in your case ) of the engine and go into two plugs , one 6 pin and one 3 pin triangle . Make sure its on the engine .
Chris
413leon
Post by 413leon »
hi rotazuk I have the injectors in the shed , will make sure those wires are there tomorrow.
As for the ugly hole in the firewall will it be hard to get a warrant if I weld a box round it to fill the hole?
It sill has a warrant and woud like to keep it warranted , does anyone have a g13b twincam gti in their roadlegal zuk
have seen a few in trial trucks eg lilpigzuk but none with wof???
Rotazuk
Post by Rotazuk »
Hi
This loom is done . If you can pass on a good day time delivery address I will get it away tomorrow ( thursday so you have it for the weekend . Will then pm you once you get it back and look at it :lol: . It just looks bad . Only 6 wires to conect to make it run , easy . Will be able to talk you through wiring it up , bit by bit .
Chris
Grrrr . your email got caught up in the spam filter . Sorted . Is the addy you send god for a day time delivery . Yes or no , if no e mail a day time one to the e-mail I gave you .
