Lada Niva "A" class truck
De-Ranged
Re: Lada Niva "A" class truck
Post by De-Ranged »
thanks for that NM thats one less worry :lol: oh and I've bought the seats so I'll use em :roll: besides they look cool :lol:
Right I've just thrown up another update
Update Link
little bit of luck I'll have a fair bit more done this weekend
Cheers Reece
De Ranged Engineering
027 541 8794
De-Ranged
Post by De-Ranged »
Right another update
Update link
I've also gotten the output drive flange for the trans off the last owner, still need to know where the trans computer is mounted as he dosn't want to strip his car :roll: but at least with the flange I can mount the transfer case and sort the drive line....
Oh the budget is about to take another hit as I'm going to have to buy a trans mount for it :( I thought I'd be able to get the old one off the guy I bought it from as he is going manual..... arghhh na, turns out they fit the manual box.... so now I'm going to have to cough up for one :roll:
Cheers Reece
027 541 8794
meatc
Post by meatc »
Hey.
the auto trans computer should be behind the passenger side kick panel. The engine comp is right there. then go up and forward to find trans comp. Occurding to the manual you will prob have to take the glove box out.
This link has all the various model silvia factory manuals. They have every thing you will ever need and more.
http://www.silviansw.com/manuals.php
Im putting a CA18DE in my toy with auto. Not using the comp for it, I'm going to make it a manual shifing auto. No overdrive but will have a switch for the torque convertor lock up to improve decent control.
Dan
Rotazuk
Post by Rotazuk »
Arggg I spent ages looking for manuals online for the nissan :(
Will download a couple at work and see what they are like .
If you wade thro the cd I sent down it has a location for the auto ecu , were Meatc said it was .
Chris
De-Ranged
Post by De-Ranged »
:roll: Had a glance at it and missed it :oops:
All good guys, and thank you for those .... now so long as I can convince the last owner of the motor to pull out his dash i stand a chance at running at easter 8)
Had a full day on it yeasterday, got the trans output to the transfercase sorted :roll: and half way through mounting both the trans and the transfercase.... having a bit of fun due to the fact I've got to clock the transfer case to help clear the trans :roll: so I've cut the old mounts off and I'm building some new ones
Right got today in the shed so time for me to go see what I can achieve....
Cheers Reece
027 541 8794
nivaman
Post by nivaman »
Hey Reece do you think you may put some pics up of the g/box to t/case coupling? give me a few ideas on how to mount the 131 Fiat box that will.
Sorry but found it rather hard to see the steering box pic, any chance of another?.
Cheers.
De-Ranged
Post by De-Ranged »
nivaman wrote:Hey Reece do you think you may put some pics up of the g/box to t/case coupling? give me a few ideas on how to mount the 131 Fiat box that will.
All I did was to run with the trans slip joint and the UJ off the drive shaft, this will work due to the style of transfer case mount :wink: (will post this up tomorrow) if you use the standard mounts the box could be nocked, tilting the transfercase allowing the slip jiont to pull... putting it out of alignment
The joint its self was time consuming to do as the silvia jiont isn't one you can pull to bit and reinstall :roll: so I had to work around it
First I cut the DS as short as I could so I could mount it in the lathe
I used the lathe to cut the remaining tube off the UJ by machining out the weld, this left a machined (true) receiver for a flange, I machined this out of solid making the hole to fit onto the UJ a moderate tollerance fit, I used a press to fit this so it would run true
When I welded it I spot welded oposites to limit weld warp
then welded anywhere I could fit a weld
No worries I'll take some more of the bump stops I'll post em up with the pic's of the X member
Cheers Reece
027 541 8794
nivaman
Post by nivaman »
Nice one, was looking at fitting the uj between the 131 gearbox and t/case but seeing as the 131 box is longer thought mmmm a three inch uj will not fit in a two inch space.
The 131 Fiat box is longer by approx 90mm but is a stronger box and seeing as i already have a Fiat engine fitted i may as well fit the box too.
The late model Niva's have a CV intermediate shaft and i plan to use one of those between the g/box and t/case, it is slighty smaller than the UJ arrangement and the 131 box is slighty smaller so i am hoping it will fit, may have to machine down the CV joint slighty though.
How many splines has the silvia joint have? and how long is the UJ part?.
De-Ranged
Post by De-Ranged »
Just thrown up the transfercase X member pics
Sorry I didn't get the dimensions on that jiont :roll: I was a bit distracted.... found out I may be struggling to get my comp licence sorted by easter :roll: apparently it takes a month to process and I can't get confermation from ORE club if my dues are up to date, or even if I'm a member :oops: dosn't help I don't know who to ttalk to in the club :roll: I'm gona have a chat to Chasse tonight and see if we can sort something, all I want to do is poke this through scrutineering ( to make certain I'm on the money) and have a play :D I don't care about pionts... oh well I might send a few more PM's see if I can track down an answer
Cheers Reece
027 541 8794
lilpigzuk
Tiger Balm
Post by lilpigzuk »
De-Ranged wrote: apparently it takes a month to process
You sure?? Should be a shitload faster than that (mine was a week). I think WJW was looking after membership, PM him
Loving the progress though 8)
wjw
Post by wjw »
De-Ranged wrote:I can't get confermation from ORE club if my dues are up to date, or even if I'm a member :oops: dosn't help I don't know who to ttalk to in the club :roll:
PM 'Mark', he's dealing with memberships since I retired. Looks to me like your memberships expired. Wouldn't take long to setup again though. He'll need your real name to cross check though.
Bill
Who knew Prados could fly?
De-Ranged
Post by De-Ranged »
thanks guys I'm just about to send a PM now
Got all of tomorrow to work on it so should be able to fling up a bit more... bit of luck I'll be able to go pick up some new, old saged springs for the front :lol: the ones I've got are to much for the front and allow next to no travel also need a steering relay arm housing :roll: the lada slipped of the jack stands and when it landed snapped the housing :shock: this was before I welded the steering stops on...
Oh and NM when I'm doing the springs I'll pull one of the spring plates and take some better pics of the steering stop for ya :wink:
Cheers Reece
027 541 8794
spanky
Post by spanky »
looking forward to seeing this thing in action as still cant get over how my mates standard shitter goes everywhere on its road tyres,i scored him some 29inch swampers with tubes for 280 second hand but not to sure i want to give them to him as he will probaly show us up :lol: ,i hope my project progresses this well once i get back into it.
vaughan
nivaman
Post by nivaman »
Reece
I do have a spare steering relay arm housing.
Would be grand to see those pics, you can use spacers on the top of the front springs if you want to raise the vehicle.
De-Ranged
Post by De-Ranged »
spanky wrote:looking forward to seeing this thing in action as still cant get over how my mates standard shitter goes everywhere on its road tyres,i scored him some 29inch swampers with tubes for 280 second hand but not to sure i want to give them to him as he will probaly show us up :lol: ,i hope my project progresses this well once i get back into it.
vaughan
So am I :lol: I'd agree they are a very under rated truck for what they can do 8) I know silverculture contractors that use them in ithe bush instead of quad bikes.... as for the progress :roll: I've still got ALOT to get done before easter... but I still think Im with in cuuee of doing it 8) I'll probably be on borrowed tires for the weekend but I should be there :D :D
nivaman wrote:Reece
All good thanks for the offer, picked one up along with the whole motor front axle assembly... hopefully the springs prove to be saged... yep you read right I want saged springs :lol: , the springs in the one I'm working on were re-set is my guess and they were so tight that the top arm was sitting on the bump stop so hard it had compressed it by about 1/2 an inche... thats all well and good if i'm trying to follow in ruts but if I have to do any X-overs I need the flex or the open diffs will stop me
Oh and for A,B,E & F class you can't run spacers in fact no modifications to the suspension
Oh and :roll: I've come up with a better design for the steering stops :wink: but I'm not gona worry about that till after easter
Cheers Reece
027 541 8794
nivaman
Post by nivaman »
De-Ranged wrote:hopefully the springs prove to be saged... yep you read right I want saged springs :lol: , the springs in the one I'm working on were re-set is my guess and they were so tight that the top arm was sitting on the bump stop so hard it had compressed it by about 1/2 an inche... thats all well and good if i'm trying to follow in ruts but if I have to do any X-overs I need the flex or the open diffs will stop me
I also have a set of standard front springs, sucks to hear about no mods to the suspension but thems the rules i guess.
Do you want to modify the stops or fit another steering box?, how about bracing the area where the steering box bolts to?, would be interested in one of your transfer case mounts if you interested in making another one??.
De-Ranged
Post by De-Ranged »
:roll: those springs, turns out there not overset, theres only about 5mm difference between the two sets at rest :roll: looks like I'm gona have to run em
The steering is all standard apart from this 8)
they are setup so the steering arm on the hub will hit at full lock they arn't perfict and will flex but they are just there to take some of the force out before its leveraged at the steering box
After easter when I'm not trapped by the budget :lol: I'll throw power steering in and replace the whole setup, including these steering stops
the transfercase mount is no problems I'll just need to know how high your mounting it ... in my case I raised the trans up to help clear the front DS, the other issue is how far do you want to clock it, I've clocked mine by about 30 deg :shock:
Cheers Reece
027 541 8794
nivaman
Post by nivaman »
While i am thinking about it, you should beef up the bottom and top shock mounts.
Will be wanting the t/case to stay in the same place so should be reasonably simple?? have got a picture so will try to post it up.
http://forum.difflock.com/viewtopic.php?t=13666&highlight=transfer+case+mounting
De-Ranged
Post by De-Ranged »
http://forum.difflock.com/viewtopic.php ... e+mounting
I'm assuming you want something like the last one on that link.... a double mount for just one side, sweet as... do you mind waiting till after the easter comp ?? or would you like it soon ??
Right thrown up a bit more for you all
Here ya go
8) got a bit of a complaint the other day about me making to much noise on sundays and after hrs..... this has sort of made things a bit difficult, hopefully it dosn't leave me short :lol:
Cheers Reece
027 541 8794
lilpigzuk
Tiger Balm
Post by lilpigzuk »
no excuses Reece, I cant make it, so you have too!!
De-Ranged
Post by De-Ranged »
:shock: I'm still uncertain if I'm gona have a race licence yet, still haven't managed to sort my ORE membership, I might have to see if the local club can sort membership real quick :lol:
the other sticking piont is the auto.... I still don't know if I'm gona be able to get that comp off the guy I bought it from :roll: I've texted him twice now with no reply and been in to see his dad...
Got to the stage I've thrown a couple of auto's on the trademe watch list that have the computers, just incase
but I've still got my fingers crossed :lol:
Cheers Reece
027 541 8794
Rotazuk
Post by Rotazuk »
Have you tried asking on a couple of the nissan forums , there must be a few guys that have swapped out an auto for a manual .
Could be a way of picking one up .
Chris
spanky
Post by spanky »
what auto ecu do you need? i can have a nosey at the yard by me.
vaughan
nivaman
Post by nivaman »
Reece
You are correct, the last pic but with double mounts on both sides.
I have at least 3 or 4 t/cases and plenty of mounts so parts are no big deal.
Am going to replace the Lada tranny with a Fiat one but it is longer by approx 90mm so am looking at something that will locate the t/case and to go forwards and backwards easily but i still want to be able to use the stock driveshafts.
I may in the future machine the t/case low gear to something suitable for crawling and there is a website that has done this, i will post the link later when i have found it.
Converting the Niva to power steering is something i have always wanted to do and the late model Niva's come out with electric power steering which fits to the steering shaft and not the box, i have also thought about beefing up where the steering box sits but what to do there i don't know??.
One way to placate the neighbour's is to say if you want anything fixed come over and see me and i will fix it for you??.
And yes i can wait untill you have free time ie NOT urgent :) .
De-Ranged
Post by De-Ranged »
For the second time... arggghhh I hate that silly save button :evil:
No worries Nivaman I can sort something like that....
Would be interested in that link as I will be able to fit 33"s under this soon 8) 31" simex's are 32.2" so after I added a bit extra to just make certain they would fit :lol:
The whole weekend access has become a bit moot, I got given the hard word, yeasterday I need to keep logging till the gear is sold, well at least untill some of it is sold :roll: so baring a miricale or Lotto :lol: , the Easter finals are out I just won't have time to finish the toy.... looks like it won't happen till the first round next season
Thanks for the sugestions guys, I've gotten the number off a local crowd that convert drift cars and I've messaged a few people off trademe something will come up.....
Right I've still got a couple of days till the gear is moved to the new job... so lets see what I can do
Oh and there is another update up for you'll
Cheers Reece
027 541 8794
De-Ranged
Post by De-Ranged »
got the front gard done :lol: its starting to look a bit F'd up 8)
Update Link...
Right fokes I'm after some feed back, since I'm not going to enter easter I'm gona have a bit more time to put into this, is anybody interested in me keeping to the $1000 budget...
What I was considering was a couple of things that are definitly outside the budget :roll:
Power steering, possibly supercharge that little motor :twisted: beef up the diffs axles etc disk brake the rear axle, black box the auto so I can tip tronic it 8) oh and some other fun bits like
Got this today :roll: was gona stretch the budget to do a set of headers 8)
Now if somebody is keen to see me enter at my original budget then I'll finish it as I intended and prove it can be done by doing the first round on budget :lol: then I'd let loose :roll:
Cheers Reece
027 541 8794
meatc
Post by meatc »
budgets are like rules ..............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
MADE TO BE BROKEN :lol: :roll: :twisted: :oops:
turoa
Pyro Junior
Post by turoa »
Ive learnt the hard way.... do it once.... do it right (even though its taken a long time for me to learn that :wink: )
De-Ranged
Post by De-Ranged »
Gotten a couple of days spare to play on this.... after talking to a few guys on some of the Nissan forums, they all feel I'm not gona struggle to pull 200+ hp out of this motor with the levin super charger :twisted: this means I"m gona have to sort the axles
I'll start with the rear first... the axles are no problem I'll just use hilux ones and respline them to fit 8) the hard part is the diff, at this stage (assuming I can find something suitable) I'm looking at modifing the diff to run another carrier replacing the 2 spider standard one with a 4 spider unit out of something else ... hopefully with bigger bearings and sidegears ... this leaves the standard ring and pinion :? fingers crossed this will be good enough
What I need is sugestions for possible donor options, what boy racer cars are worth looking at
Oh and the grand limit is out the window... the super charger has just blown that 8)
Cheers Reece
027 541 8794
nivaman
Post by nivaman »
Reese,
You can use a Toyota Hiace van rear diff, unsure what van you can use but i do know it comes with disk brakes and limited slip, that way you might be able to use Hilux parts if needed.
For the front, build a steel case front diff out of the rear diff housing, or see how a Suzuki mounts the front diff?.
How is the t/case mount coming along?.
