Ashley gorge
Ashley gorge
Has anyone been right through the gorge and is it possible.Would anyone be keen sometime
Death to the competition
Re: Ashley gorge
from which end?
We have been up from the camp ground about 3-5 kms. But not for at least 4 years. Some decent sized water holes and rocks under the water line.
Used to be a nasty hole about 10 ft or more deep that went bank to bank and had a very soft pea gravel base that stopped us. may be different now though.
Go and have a look
Go and have a look
Re: Ashley gorge
from the camp ground ive been up a wee way soft as and big rocks under the water like you said
.would be best when river is very low i would imagine but could be a good challenge
Re: Ashley gorge
Id be keen ive been up about 2km wasnt to bad sum nice big rocks
Re: Ashley gorge
I think about 5 trucks would be a good number it would be a hardy trek.ill wait and see how many people are keen.those tyres on your cruiser would love the bocks
Re: Ashley gorge
should do
i cant go this weekend starter motors rooted and i gota knock over a bilding in the middle of ranigora sat and mayby sum of sunday keen 4 the weekend after tho
Re: Ashley gorge
sweet ill keep it in mind.is that the building that got burnt
muddyplumber
- Spring Free
Re: Ashley gorge
im keen to go on some sort of adventure next weekend, got wild foods this weekend and im buyn the ex 4wd upgrades big horn so im keen to take that out for a spin
Re: Ashley gorge
Good stuff man cant wait to check it out must be a beast
hope shes sealed up there will be deep holes in the gorge by the sounds of things.
Re: Ashley gorge
zookfest wrote:Good stuff man cant wait to check it out must be a beasthope shes sealed up there will be deep holes in the gorge by the sounds of things.
Good traction for the most part, you wouldn't want any more than 5 trucks (imho
At least one traction aid is almost mandatory, And if you are not coiled, or sprung over, I reckon 35" tyre size is minimum (unless on small axles, zook etc).
As an aside to the guys who are going, if you get all cry baby about scratches, dings, broken bits or washing the berber, stay at home. It is a trip where there is defenitly a much higher chance of damage than mud bunnying around the mak.
Take the advice any way you want, and above all, have a really good trip guys
Re: Ashley gorge
sounds good i may get to use the bilge pump and give the baja claws sumthing to do for a change.and test the external cage
if its ready
Re: Ashley gorge
Na its the old second hand shop just off high st. sweet the cruzer should handle it give the new 35s good test
- hosehustler
Re: Ashley gorge
I'd be keen to head there, busy up until easter tho
Like Rok said, it will be nasty in places so if you dint, bend, or tip on your side, just accept that it's all part of the fun
I hate signatures
