More power from a 3B
85BJ73
Post by 85BJ73 »
Okay, these 3B things have been around for a while, how can ya get more power from them, without a huge expense, and hurting reliability. I don't wanna have to turbo'supercharge it either, not making things easier here am I? :roll: .
I know I am looking at a transplant in the future, but in the mean time, are there any cost effective ways to get more out of the 'ol lump? Basically looking for cheap power from what I have!! :D
Thanks,
Shane
No matter the problem, the answer is always give it more gas.......
Modded 1985 Landcruiser, semi restrained nutter behind wheel.
smurf182
Re: More power from a 3B
Post by smurf182 »
Install an EGT gauge and crank the fuel up. You're not going to get much out of it without a turbo though, you might even find the EGT is reaching scary levels on the factory fuel setting.
KiwiBacon
Post by KiwiBacon »
I guess the first question is: Can you afford to blow it up?
If not, it's best left stock.
85BJ73
Post by 85BJ73 »
Good point, it stays stock.... 8)
To be honest other than a turbo or an engine re-power for your truck I think what you've got is about all you'll ever get :?
The 3b's a low reving torquey oil burner and thats all it'll ever be
85BJ73
Post by 85BJ73 »
Funnily enough there have been very few occasions where more power would have helped, but more rev's........ :? :?
But we all percieve we need more power, and I guess the correct question I should have asked, rather than about the 4.500 V8 was what oil burner should I look to replace the 3B with, and I wanna stick with Toyota too.
Shane
KiwiBacon
Post by KiwiBacon »
85BJ73 wrote:Funnily enough there have been very few occasions where more power would have helped, but more rev's........ :? :?
Shane
15BT sounds like the one to have.
Similar package to your 3B, but bigger displacement, direct injection and turbo'd.
Even a 1KZ would be nice, but the 15Bt would be better and probably easier to fit.
85BJ73
Post by 85BJ73 »
15BT? :? I've heard of a 13BT, but not a 15BT. I had considered one of those, and when the time comes I think that is what I will look for, but do they perform down low like the 3B, or does it need to be on the turbo?
Shane
KiwiBacon
Post by KiwiBacon »
85BJ73 wrote:15BT? :? I've heard of a 13BT, but not a 15BT. I had considered one of those, and when the time comes I think that is what I will look for, but do they perform down low like the 3B, or does it need to be on the turbo?
Shane
I haven't seen a 15BT either, but they're fitted to the MEGACRUISER among other things. I've driven Dyna's with the 14B (non turbo, direct injection 4.2 litres I think) and was quite impressed. Very quiet and smooth, much quieter and smoother than my Isuzu 4BD1T.
But yes it needed a turbo.
niblik
Post by niblik »
i've sourced a 4 litre turbo diesel engine to repower a 40 with.. could be an option if ya find one for the right price?
still, cant go past the 3b for 'all day every day' performer. not a rocket ship, but thats the sacrifice ya make for reliabilty. :wink:
Is the problem power or traction? my little wee Cruiser Jr is not a huge powerhouse but a rear difflock has made it so much better, finding that don't need to rev its nuts off to get places (usually).
What about a cheap EFI or something?
Saddam will have a spare 302 very soon :lol:
85BJ73
Post by 85BJ73 »
I wanna stick with an oilburner, so the 302 is out. I built a 351 out of a 302 once, the 351 is far better than a 302, and cheaper to run too. I'm talking the Cleveland here, not Windsor. :D
Yup, traction has been part of the problem, especially on Papa, which is the prevalent surface here, but revs/power will/should clear tyres better. EDIT: I have front and rear difflocks, and 33" Maxxis Buckshot Mudders, that were only 1/4 worn. I have a new set of Maxxis BigHorns that I will be trying in a week or two.
But, as I said earlier, the 'ol 3B has never let me down, I am just wondering what options I have, and wheter they really would be any better.
Shane
KiwiBacon
Post by KiwiBacon »
If you aren't worried about sticking with Toyota, then an Isuzu 4BD1T would make that fly. :lol:
Mine is pushing around 500Nm just with more fuel and boost. Spins all four on gravel up to 80km/h :twisted:
85BJ73
Post by 85BJ73 »
Done a little bit of looking into a 14BT and 15BT, depending on power and rev figures it looks like a good option. :D Going by the other forums, it looks like they will fit the 'cruiser, and one forum mentiond it was the perfect swap for a 'cruiser 8) ....so watch this space, maybe I can find one at a good price......the only downside seems to be the rotary fuel pump, but maybe I could get someone to adapt a mechanical one....or are the rotary type ok?
Thanks all,
Shane
85BJ73 wrote:Done a little bit of looking into a 14BT and 15BT, depending on power and rev figures it looks like a good option. :D Going by the other forums, it looks like they will fit the 'cruiser, and one forum mentiond it was the perfect swap for a 'cruiser 8) ....so watch this space, maybe I can find one at a good price......the only downside seems to be the rotary fuel pump, but maybe I could get someone to adapt a mechanical one....or are the rotary type ok?
Thanks all,
Shane
if you search out the posts from adventures_more whos nolonger on this forum he posted a lot of threads about these engines last year
KiwiBacon
Post by KiwiBacon »
Thanks all,
Shane
Some rotary pumps are all mechanical, some are electronic control.
I don't see a problem with an electronically controlled pump, user adjustable tuning boxes are available for them.
85BJ73
Post by 85BJ73 »
Looked up the ols posts, he did some research, but not enough to give me the answers I wanted... :?
But I found a place in NZ, Blairs, so I am trying to see what they can tell me about the 14BT, they don't list the 15BT, as yet :?
I will see what I find out, and post my findings here.
Shane
85BJ73
Post by 85BJ73 »
Just heard from Blair's in Auckland, a 13BT motor, complete, $3250 +gst & freight, I guess that is not too bad for a complete motor, with a warranty and has been run on a test bench. It definately works out cheaper than a recon job.
I have asked about a 14BT, as soon as I hear back, I will post that too.
Has any one dealt with them? Any feedback?
Shane
85BJ73
Post by 85BJ73 »
They have no 14BT's but they have a 15BT, $5950 +gst & freight.
Thanks to all who have posted, I will proboably go for one of these three options when the time comes 8)
I appreciate all of the many replies, and I hope to meet up with the various people on this forum.
Shane
