tweake wrote:KiwiBacon wrote:tweake wrote:routing egr pipe to pre turbo will just make things way worse as you will be bleeding off boost back to the air intake. ie like a BOV thats stuck open.
far easier to block the crap off and disable the butterfly.
The plan was post turbo (he mentioned pressurised air).
??? exactly, bleeding off boost (after turbo of course) back to inlet.......which achives absolutly nothing other than makeing perform worse.
It would simply be bypassing boost around the throttle plate. From turbo to intake manifold via a different path.
It has the advantage of not having to monkey with the throttle butterfly. I can't see how it will hurt performance.
