Terrano injector pump.
Dr Rocket
- Bush Crasher
Could someone tell me if the potentiometer on top of the injector pump on my TD27T is only for the EGR or not. I am going to remove all the ERG components and that will go if its not needed.
Re: Terrano injector pump.
don't know for that exact vechile but often if its mechanical pump then the tps is only for egr. however they are also often used for autos. i usually just get rid of egr gear and leave the sensors alone.
likewise.when i removed egr i left all the sensors and that potentiometer thingy in place....whats it matter?weight reduction of like 100grams????
i doubt it has anything else to do,other than egr crap,as i installed a turbo td27 into my navara,and that potetio-thigny wasnt reconnected and ute runs perfectly fine.
