BALL JOINT SPACER
kicker
BALL JOINT SPACER
Post by kicker »
WONDERIN IF ANYONE KNOWS WHERE TO GET HOLD OF BALL JOINT SPACER FOR A 92 SURF, IN NEW ZEALAND, ALSO ARE THEY LEGAL WITH A CERT, I KNOW THEY USE THEM IN OZ AND THE STATES BUT THERE REGS ARE FAIRLY DIFFERENT. HAS ANYBODY HAD ISSUES WITH A 50MM BODY LIFT????????? CHEERS :D
PigFmr
Re: BALL JOINT SPACER
Post by PigFmr »
hi
give(Kev) worzel a PM he has body lift and ball joint spacers,
vince
kicker
Post by kicker »
OH CHEERS MAN. MAT
CHCHilux
Post by CHCHilux »
Just got some ball joint spacers put into my surf and yup they're legal with a cert. If you have to cut or modify the A arm in anyway then defiantly talk to the cert guy first, mine wanted to take pics before and after and wanted a letter from the engineer that did the work! :cry: :cry: :cry:
kicker
Post by kicker »
what size did you use, did you have to space your diff and sway bar, iv read that they put stress on cv joints due to excessive angle
86-surf
Post by 86-surf »
i member some one saying that you can put a 1'' spacer or washes in the front rear diff mounts?,
Can some one confirm this?
And i have just receved my body lift from Taz01 on this website,
muddyhilux
Post by muddyhilux »
hi jase,can confirm this is true as ive done it to my rig,and does do a good job returning the c.vs to better angles
86-surf
Post by 86-surf »
Thanks for confirming
kicker
Post by kicker »
wot size spacers are best applied
UBZ
Post by UBZ »
have a look at this site
http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
alot of useful info on ball joint spacers and Diff drops
Return to “Toyota”
