After a set of drop boxes to suit a 99 Safari (GQ ones fit)
Need ASAP.
Dave
Safari Drop Boxes WTD
Re: Safari Drop Boxes WTD
hey dave any luck yet? my mate made mine they are top quality. You dont know where i could get a alternator from do you? that one i bought off ya a while back has shat itself. Well the vacuum pump has and has stripped the axle out the back of the alt that drives it
Na, not yet, still tossing up between bushes and boxes, as, being a 3" lift, its sort of between both for either being right for it
I'm sure I've got a spare pump and rotor, well a complete alt, but the stator is buggered, so if you can get the rotor assembly out, you can have it, will just need to track the pump down
Dave
Dave
Yip, got it here if you want it
i got a 3" lift and went with the drop boxes i wanted to keep the standard nissan bushes as they flex better. Plus by dropping the arms at the back it gives a little more protection to my exhaust etc
