have searched and read alot about the mounting of rated recovery hooks but still want clarification.
how have people mounted their hooks on the front of a Mu or wizard? (being almost identicle at the front)
i was thinking of silding some angle steel down inside the end of the chassis rail and putting 2 or 3 bolts in the side of the chassis to add strength. then mount the hook on the bottom of the chassis rail with the bolts coming up thru the bottom of the chassis and onto the same piece of angle. angle steel is 6mm thick.
will this be ok?
and second question is;
does anyone in the hamilton area want to help me for a box of beers?
