Surf water temp sensor
NFORCA
Post by NFORCA »
Hey guys. The on going drama of my surf continues.
The ecu is coming up with a faulty water temp sensor code. So i replaced the sensor that activates the gauge. Only to find out there is another sensor aswell.
Where is the sensor that tells the ecu the water temp? (1KZTE)
Todd
wjw
Post by wjw »
HAve a look at this:
http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf
Found it when looking for engine codes for my 1kz, its the complete toyota service manual :)
Who knew Prados could fly?
NFORCA
Post by NFORCA »
Cheers. Judging from that its up behind the oil filter. As soon as it stops pissing down, I'll go take a look.
NFORCA
Post by NFORCA »
Got it sorted. It appears the problem is that I'm a retard. When I installed the motor i didnt get the rear water temp sensor plug in.
Thanks for your link WJW, if it wasnt for that I'd still be trying to find the damn thing!
wjw
Post by wjw »
No problem :)
oldblue
Post by oldblue »
Im on diel up , how long would this web site take to down load? Seems to be taking ages.
Kevin.
snow
Post by snow »
oldblue wrote:Im on diel up , how long would this web site take to down load? Seems to be taking ages.
Kevin.
Its 14.1 MB, probably about 1 hour.
Have welding rods will travel
oldblue
Post by oldblue »
Your so right, took 1.1/2 hours
Kevin.
wjw
Post by wjw »
It was a bit big... only one I could find in 1/2 hr of searching though, most links didnt work :(
Return to “Toyota”
