WANTED/NEEDED! ifs 4.88 diff head!
86-surf
Post by 86-surf »
What the title says, needs to be in good condition,
Re: WANTED/NEEDED! ifs 4.88 diff head!
I think Taz01's going to be wrecking his white surf when he picks up the new rolling body from Nailz, dunno what ratio his diffs are but you might as well send him a PM and find out
And if he has got a diff for you he'll have to sell it to ya cheap coz he owes me a favour :mrgreen:
taz01
Tazzles
Post by taz01 »
will only have front spare 4.3 can have complete diff unit if you want cost of freight
WARNING:
I thought he had already wrecked his white surf in Rallywoods :shock: :lol:
what bits do you need, Gazza has a pile of broken ones :roll: otherwise Dwayne Mead collects them to sell to 4wd'ers, he has his number I think as well, may be worth PM'ing him
GotFlex
Post by GotFlex »
hi i would be very keen i will pay for it, im sourcing all the parts for my SAS
haynzy
Post by haynzy »
Im not sure they made a4.8 ifs diff 4.5's as low as they go but hey ive been wrong before
Jerry wrote: otherwise Dwayne Mead collects them to sell to 4wd'ers,
I asked my flatmate Dwayne and he said they are very hard to come by, if you can find one at all.
Jezza
Post by Jezza »
Isuzu Mu 3.1TD
86-surf
Post by 86-surf »
dwayne... that rings a bell. he txted me the other night asking what ratio i wanted he aint got none:(,
i know ifs has a 4.88 nzhunter had one, Im prity sure taz01 does to but hes using it!.
I need 4.88's to turn my 33's, but if i can't find 4.88's it will have to be 4.5's and maby a little bit of a repower or somthing:(.
Taz01.
My brother inlaw put the 2.8 in the hightop van so i won't be using the 2.8, But now i have a spear head and turbo etc etc etc
86-surf
Post by 86-surf »
Hes talking about a ifs front end(i think) Which is diffrent to solid so no use to you
SWB prados like my LJ71 use the 4.88 diffs, the odd surf like Gazza's one uses them too
and no you can't have either of mine :twisted:
gazza
Post by gazza »
Think i,ve used most of the 2nd hand 4.88 diffs in new zealand. Took me a longtime to locate the last one goodluck :roll:
NO one remembers who comes 2nd....!
86-surf
Post by 86-surf »
gazza wrote:Think i,ve used most of the 2nd hand 4.88 diffs in new zealand. Took me a longtime to locate the last one goodluck :roll:
in that case! give me yours!!!
taz01
Tazzles
Post by taz01 »
nah its broken as well,
i havnt checked my new one yet but if it is 4,88 IM KEEPIN IT.............
thank for offer on parts but i have a white one here that will be stripped by next week so will have a shell with all interior intact free for the taking
WARNING:
gazza
Post by gazza »
Sry jase its going into me truck as have broken another :cry:
Heath
Post by Heath »
Who was looking for a new body to replace their burnt out one?
EDIT: Search for 'Fire' thread
Im after a solid axle chassie and a 85 to 89 old fiberglass back surf body
for those of you that dont know I was in the shed welding a falcon bracket onto my rig and the whole thing cought on fire. as it turned out it destoryed my shed and my crawler but the crawler was not insured so have to rebuild.
to add insult to injury the insurance company is going to screw me over with my tools and motor parts so I will be out of pocket by about 30 grand
but the stupid thing was the fireman did not put the fire out and it took out half the house as well
so im after a new body and chassie in the canterbury , it dose not need any running gear or motor in it , will take a ifs body as they are the same may also consider a 4 door body if its the right price
cheers chopper
taz01
Tazzles
Post by taz01 »
its a ln130 ifs 90 model yours if ya want it but long haul to the big smoke ..........
WARNING:
one careful elderly owner only driven on sundays thru rallywoods eh :lol:
taz01
Tazzles
Post by taz01 »
not often on sundays..............................mainly cause i broke it saturday
WARNING:
Heath
Post by Heath »
taz01 wrote:its a ln130 ifs 90 model yours if ya want it but long haul to the big smoke ..........
Not for me Maybe Chopper would be interested.
86-surf
Post by 86-surf »
ok ive found a 4.88 diff head for $300 out of a 93 surf, will this fit into a 86 surf?
UBZ
Post by UBZ »
It will need to be full front IFS diff setup and not just a diff head to go in the front of a Surf.
Does it have ADD? Do you have a non-ADD diff to convert the ADD diff with??
What ratio do you have in your surf at the moment? I only have to to go from 4.1 to 4.3 ring and pinion to return to stock gearing (going from factory 31's to 33's). When I want to go lower I will get 4.5's or change transfer case gears.
have a look at this site has a good easy to understand ratio calculator in the technical section
http://www.sugarloaf4wd.com.au/
I went through the process of looking for 4.88 IFS diffs a few months ago, and have decided not to go down that path. As IFS fronts in that ratio are very hard to come by, and I have all ready blown two 4.1 front IFS diffs.
86-surf
Post by 86-surf »
at the moment i have 4.3 diffs.
i have no idea if it's add or not, i don't know if mine is add eiver....
Mines a 86 and his is a 93, so i have no idea?
UBZ
Post by UBZ »
Top is a Non-ADD IFS diff
Bottom is the ADD passenger side axle shaft, with vacuum operated disconnect.
Both are interchangeable. (I'm assuming the 93 diff is ADD)If you have a Non-ADD setup on your truck you will need to put your passenger side axle shaft on the newer ADD diff.
This is a great link for Toyota Diff information.
http://home.4x4wire.com/erik/diffs/#rear
What tire size did your truck come out from factory with?
86-surf
Post by 86-surf »
thanks.
I have no idea what size tyres mine came from the factory, but it came with the 31x10.5's its got now wen i got it.
GotFlex
Post by GotFlex »
hey my mate runs 35s with 4.3s and it is goes mint, i wouldnt bother changn them ae personally,
Smurf
Post by Smurf »
An 86 surf won't have an ADD diff.
I used to run 33s on my 86 IFS surf with 4.3 ratio diffs, no slower than it was on 31s.
It was still slow, once it was in low box it was fine.
cool__bananas
Post by cool__bananas »
when you change to a 4.88 they become weaker, the lower the ratio the weaker the diff gets, so be careful about that
