Air Tank Pressure Test
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
donjohnson
Post by donjohnson »
Anyone know somewhere in Christchurch to pressure test a tank to be used for an onboard air system?
The tank is off a truck, used to be used for air brakes but it's a but old so I want to check it out.
moonhopper
Re: Air Tank Pressure Test
Post by moonhopper »
TAKE IT DOWN TO DIVE HQ AND ASK THEM IF THEY CAN DO A HYDRO ON IT FOR YOU.
aroma
Post by aroma »
last time I tested on I pluged in to works compressor sat it out side and hid on the other side of the workshop till compressor stopped the peeked around the corner to check
A it was still there
b wasn't leaking
c then sprayed with soapy water
could do that for you if you wanted
03 9421069 hm
Warren
rayndeb
Post by rayndeb »
theres a place down hayton rd in sockburn they test gas cylinders and stuff.. its called c test 52 hayton rd
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Return to “4wd Safety”
