Ball Joint Flip
red-devil
Ball Joint Flip
Post by red-devil »
Does any one have/ Can make the spacer that is need for the ball joint flip.
Cheers Jono
WACKO
Pyro
Post by WACKO »
you dont NEED the spacer, you know that aye?
WACKO
Pyro
Post by WACKO »
red-devil
Post by red-devil »
opps sorry no i didnt :oops:
Ilike the idea of 10mm blots so thanks
jono
red-devil
Post by red-devil »
Cheers for the info, Flip all done in 2 hours this avo :)
Jono
WACKO
Pyro
Post by WACKO »
easy as aye? you do the 10mm bolts at the same time?
red-devil
Post by red-devil »
Yes after looking at it and thinking need bigger bolts.
im thinking about finding some spacers ( 10- 15 mm ) to gain a little more space for the upper bump stops.
or just trim the bump stops down a little
Jono
WACKO
Pyro
Post by WACKO »
i just trimmed mine. everyone else seemed to do it so figured it cant be all that bad... what sort of paj have you got?
red-devil
Post by red-devil »
91 soft top 2.5d turbo.
mods so far
93 long wheel base rear spring in rear for the gain of 50mm height
lose the front and read bars for a nice 6mm steel C channel :lol:
33 seringetis on 7" rims good for airing down to 10 psi just takes a while to pump back to road prussure.
Front tersons bars are cranked up about 30mm
ball joint now just check the front height gain another 10mm :P
body lift 50mm
but have 1 problem
gear bos shagged lost sinkros in 2nd, 3rd, 4th
Transfer chain slipping baddly ie cant use 4x4 at all :cry:
jono
WACKO
Pyro
Post by WACKO »
that sucks. ive got 93 soft top 3ltr v6 man
33" seringetis
raised lwb king springs
balljoint flip
removed front and rear sway bars
but my inner cv gave up and im having trouble finding a decently priced replacement now so i have no wheel drive :cry:
JTop
Post by JTop »
I have a complete transfercase in good nick plus a smashed 1 which did have a good chain spare
J Top
red-devil
Post by red-devil »
hello there jtop
how much for the good tranny case.
and have u any ideas on were i can find a gear box too.
were bout are u too so i can work out shipping :(
JTop
Post by JTop »
Wgtn
you might get a better deal buying them both together somewhere.
I thought the T/F case was $300=$400. done 90ks
J Top
stinky001
Re: Ball Joint Flip
Post by stinky001 »
hi does anyone have any pics that they can show me of a ball joint flip thanks steve
cyclops
Re: Ball Joint Flip
Post by cyclops »
viewtopic.php?f=18&t=2159&st=0&sk=t&sd=a&hilit=pajero#p17117
check this link out great story on mods done by NJV6
rayndeb
Re: Ball Joint Flip
Post by rayndeb »
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
Return to “Mitsubishi”
