turbo options for safaris
For all Nissan related topics
mudhunt
Post by mudhunt »
Hey im going to turbo my 4.2 diesel. Im currently looking at an axt turbo kit ex australia. Has anyone used one of these? if anyone know a cheaper option or a better option any help would be appreciated
PR
In the crap again
Post by PR »
(021) 02388443
GQTROL
Re: turbo options for safaris
Post by GQTROL »
mudhunt wrote:Hey im going to turbo my 4.2 diesel. Im currently looking at an axt turbo kit ex australia. Has anyone used one of these? if anyone know a cheaper option or a better option any help would be appreciated
AXT are a good kit, and ideally suited to someone that tows a decent sized boat or caravan. They are great down low, but have no top-end due to their small exhaust wheel size. Can be very restrictive above 110km/hr compared to other kits.
Good quality components, we've had one on a NZ new Patrol since 1992 and my grandfather's NZ new Patrol since 1991.....both have done well over 400,000kms, both turbos on since trucks were new.
mudhunt
Post by mudhunt »
yeah sounds like they are a reliable kit from what ive heard i think ill run with them. I dont really wana go and do a home job id rather spend the extra coin and get a kit that has been researched and tested. Ive heard of a guy in chch that fitted one five years ago and has run 17 pound since then and had no problems. Obviously he made a few more mods full exhaust and more fuel etc but yeah reliable! Im only intending on running the recommended
doby
Post by doby »
Eneyone know where i could find a complet turbo setup of an already turboed TD42 sarari? have ben looking on the net and found a few nice new setups but they are a bit out of my price rainge at the mo. Thourght i might be abel to find somone with one siting around, or maby somone wrecking a turbo safari?
gary_in_nz
Post by gary_in_nz »
how did we go with the AXT Turbo kit?? any updates?? how much was it going to cost to get it landed here in NZ from Aus??
mudhunt
Post by mudhunt »
they are too expensive i thought and mixed reviews
KiwiBacon
Post by KiwiBacon »
That link now appears dead. :(
If you can find a manifold, then the rest is reasonably easy. The manifold flange dictates your choice of T28 or T3 based turbos.
gary_in_nz
have you gone for a turbo setup at all??
mudhunt
Post by mudhunt »
yep i did went custom my mate built it from scratch including manifold
carver65
Post by carver65 »
Considering doing the same .What turbo did you use? How much? And what did your mate fab the manifold with? I was thinking of using Black But Weld pipe fittings and hand gas cut flanges .Mill the faces at local MC shop.Get friendly diesel shop to match pump and tune. Fab up a 3'' pipe with expansion joint. Any photos ?
gary_in_nz
I just emailed AXT Aus and they said $2990.00 Aus $$ and $350.00 Aus $$ to get to my door. so thats under $4000 NZ, any Gst that I would have to pay?? Still sounds better than my $7,000 quote i got!!!
TJ
Post by TJ »
gary_in_nz wrote:I just emailed AXT Aus and they said $2990.00 Aus $$ and $350.00 Aus $$ to get to my door. so thats under $4000 NZ, any Gst that I would have to pay?? Still sounds better than my $7,000 quote i got!!!
12.5 % GST and Custom processing fee (about $40).
gary_in_nz
Hi Gary,
We can get AXT Turbo kits, But we prefer to sell & fit DTS Turbo kits, I will scan some info as an attachment.
Turbo Kit (water cooled TD05H turbo) -$3750.00
Fitting -$ 600.00
Dyno & Pump Tuning -$ 80.00
Total -$4430.00 + gst
We will dyno the vehicle first with reading & dyno the vehicle after fitment & tune up.
We recommend changing the oil & filters when the turbo kit is fitted ( For Warranty Purposes)
The other things this motor responds to is Tappet clearances & injectors
I also emailed Tauranga Diesel who said they will do this, which seems reasonable, less mucking around than getting gear from Aussie
sig
Jeep Jeep
Post by sig »
if you do make your own manifold make sure you put a slip joint in it ,otherwise the heat distorts it so much it keeps blowing exhaust gaskits.i put a hilux ct20 on my old patrol about 5 years ago and its still going strong .
albundy
Rolly Polly
Post by albundy »
Rumour has it a guy is repowering 4.2 safaris with a turbo kit for 3k fitted. He is in Kaiapoi just nth of CHCH. Going out to see him this saturday, have a chat as I think this may be the next mod.
Al
TheDarkSide
Post by TheDarkSide »
A lesson I learnt from doing my conversion is that you need to get a diesel pump with a vacuum compensator on it (factory turbo's have them) unless you want to smoke prior to boost or lean out when on boost.
Has to be said though that putting the turbo on was by far the best thing I ever did, it has transformed the truck!!!! I was lucky enough to find a rusted old Saf that had a Safari Turbo (brand) kit fitted to it, got it cheap, stripped all the good bits and wallah!!! a Cruiser Killer!!!!
Good thing about the Safari Kit is it has a 3" outlet and comes with a 3" exhaust as well (removed the muffler, sounds good), this means good at the bottom end, but great power at the top (easily goes past the redline) and all this at only 10 pounds and 500º (max) EGR.
Pete
mudhunt
Post by mudhunt »
does the turbo have a 3" outlet? is that 500 celcius
TheDarkSide
Yep,
3" outlet on the turbo and 500ºC (550º is the max before meltdown).
Pete
KiwiBacon
Post by KiwiBacon »
TheDarkSide wrote:Yep,
Pete
Do you have your EGT probe after the turbo?
If so, the melting point is a guessing game.
mudhunt
Post by mudhunt »
where should the pyro probe be installed
darinz
Post by darinz »
We've just killed a TD42 with 550*C egt's! And that is manifold egt ie pre turbo. Admittedly we don't think it is an egt problem that has killed it. I ran my old motor with 550*C egts and I did about 70K at 20psi before I sold the turbo to fund current engine. At 10psi it is hardly going to effect anything and is only really scratching the surface of what it will do with a Safari kit. That was what I had and the difference between 10psi and 20psi is amazing!
The most acurate reading for egt's is before the turbo. A turbo uses heat to work so after the turbo the egt is reduced by between 50 and 150*c depending on who you listen to. Some people don't like putting it before the turbo as if the probe fails it will go through the turbo and damage it.
mudhunt
Post by mudhunt »
hmmm id better get mine changed over then as its after the turbo
Nizsafari
Post by Nizsafari »
albundy wrote:Rumour has it a guy is repowering 4.2 safaris with a turbo kit for 3k fitted. He is in Kaiapoi just nth of CHCH. Going out to see him this saturday, have a chat as I think this may be the next mod.
Al
Did you manage to catch up with this guy from Kaipoi Repowers???? what was the outcome... Cheers
albundy
Rolly Polly
Post by albundy »
Yeah had a quick chat with him on the trail one day. 3.5K for whole thing. Can't remember exactly what they used but it wasn't factory. Have spoken to a customer of theirs who seems pretty happy with it thus far. If youy want to know more, call them.
Al
BEAUTGQ
Post by BEAUTGQ »
you guys with custom setups what turbos have you used. im looking at doing mine just got to decide on what turbo then get manifold to suit. looking at using either td05h, or t28 or sim. Any ideas? Where did you get your manifold from how much? any help much appreciated
Cheers Jared
doby
Post by doby »
Both the turbos you have menchend are good options, just remember the lower the a/r rating the sooner it will come on boost, witch is what you wont in a diesel. I got perfomance metal works in Silverdale to make a custom hi flow manifold for me. Im in Takapuna if you would like to take a look, just flick me a pm.
KiwiBacon
Post by KiwiBacon »
There's a guy on outerlimits in Aussie planning on selling ballbearing turbo kits for patrols etc.
I've suggested he sell a basic kit of just turbo, manifold and oil lines to allow the DIY guys a good step up. The manifold is the hardest part.
BEAUTGQ
Post by BEAUTGQ »
whats the go with the bearing set up on turbos some are ball bearing some are thrust bearings to certain degrees? price varies greatly would the cheaper option be ok on a td42???
KiwiBacon
Post by KiwiBacon »
BEAUTGQ wrote:whats the go with the bearing set up on turbos some are ball bearing some are thrust bearings to certain degrees? price varies greatly would the cheaper option be ok on a td42???
Ball bearing turbos spin more freely (so spool up a bit quicker), but bushing turbos are more tolerant of poor oil quality and cheaper too.
Return to “Nissan”
