Suzuki rear disc brake conversion
For all Suzuki related topics
turoa
Pyro Junior
Post by turoa »
If I made a suzuki rear disc brake conversion kit, how many people would be interested in buying a kit?
Price would be dependent on time taken to machine the parts, and material cost, and you would have to send your old drums in.
Turoa
Ryan
Post by Ryan »
i may be interested depending on cost and how easy the fitting is....
UBZ
Post by UBZ »
I have a mate who would be keen for one of these kits for his SJ410
let us know how costs work out.
QUADRACER
Post by QUADRACER »
was just in the process of this myself, but would buy a kit if you make one
PM me please
mroffroader
Post by mroffroader »
I'll buy one if your doing them for vitara's aswell :D
turoa
Pyro Junior
Post by turoa »
mroffroader wrote:I'll buy one if your doing them for vitara's aswell :D
I think the axle flange on a 413, 410 and a vitara is the same? Ill have to do some measuring, the only different parts between the kits would be the brakelines and hand brakes (I think).
Submercer
Post by Submercer »
While you're at it can you solve the hand brake problem for the Samurai guys
QUADRACER
Post by QUADRACER »
will need to run a calipier with hand brake set up, Subaru Justy or 95 on Hondas, this is what i will use
MAHINDRACJ4A
Post by MAHINDRACJ4A »
would be keen depending on price for my mahindra cj4a been told is same as suzuki
1977 Mahindra CJ4A - 1GGTE 260hp Supra Engine - 3" Lift
tara13
Post by tara13 »
could be keen for a vitara set depending on cost
Helga410
Re: Suzuki rear disc brake conversion
Post by Helga410 »
turoa wrote:If I made a suzuki rear disc brake conversion kit, how many people would be interested in buying a kit?
Turoa
My mate UBZ posted interest on my behalf earlier, in the mean time..
I have just bought a Spidertrax conversion set in from Rocky Road Outfitters in the US. I will try a put a pic up of them with main dimensions for you if that is of help?
84 SJ410V, 1000cc, OME 2" spring kit , 2" extended Shackles, 1&3/4 "extractors and 15" coby ,rear lockrite, 29" SATs
This is not the greatest truck in the world..this is a tribute!
QUADRACER
Post by QUADRACER »
have we got any further with this, as in need of some brakes, getting sick of chewing through rear shoes :(
lilpigzuk
Tiger Balm
Re:
Post by lilpigzuk »
Unsure of the axle flange mount . You can use either 413 callipers/discs or vitara calliper/discs, not mix between the two. On LilPig Ive used vitara callipers and discs. On the new toy Ive used 413 front callipers and discs. Both have been with the spidertrax kit, but they dont advertise this as a samurai/413 AND vitara/sidekick kit. brakelines are the same between the two, just "flexed" the flexi hose too meet the brake pipe on both
QUADRACER
Post by QUADRACER »
is the handbrake assy on the transfer case, will be looking at calipers with hand brake assy on them.
early model Subaru, or 95 on Hondas.
have ordered a kit . :)
Big-AL
Post by Big-AL »
My yellow sj413 had discs on the rear when i bought it. i think they are off the front of a 413. But its got the standard master cylinder. i changed the pads a few weeks ago and now the pedal is soft like a clutch, it wont build up any pressure, i have bleed the brakes, looked for leaks, and tried putting in another used master cylinder. Do you usually have to change to master cylinder to get a bigger bore size for the rear? if yes, does anyone know what a good substitue is? otherwise any idea's as to why my brakes wont bulid pressure?
Heath
Post by Heath »
I have (IIRC) heard of using the master cylinder off a subaru. Cant find the link now but will check if I have it somewhere in my pile of printed stuff. Have a look on outer limits forum in the bible (be careful to ask any questions though as they tend to flame anyone who asks basic questions without doing a search)
Link to someone on here with suby master - viewtopic.php?f=23&t=10986#p119337
Heath
Submercer
Post by Submercer »
According to my reference you should be able to use one off a:
1998 - 2002 Forester
2000 - 2003 Imprezza
1998 -2003 Legacy
2001 - 2003 Outback
I'm looking too.
Steve.
Big-AL
Post by Big-AL »
nice, thanks guys. if there is no leaks in the brakes, and the brakes are bleed correctly, it has to be the master cylinder huh?
Submercer
Post by Submercer »
I should add that the Subie MC is not an exact straight swap. You have to extend teh push rod a bit but there are plenty of how tos on that. Search on Zuwharrie.com.
kiwitonita
Post by kiwitonita »
I need a rear disc conversion for my SJ410. I'm located in Christchurch but the Suzuki will soon be transported to Invercargill. Any tips on if this offer is still available - or who could do the work in either city would be appreciated. Thanks - Tony
Ben
Post by Ben »
kiwitonita wrote:I need a rear disc conversion for my SJ410. I'm located in Christchurch but the Suzuki will soon be transported to Invercargill. Any tips on if this offer is still available - or who could do the work in either city would be appreciated. Thanks - Tony
I make a kit to run stock front calipers on the rear, and another kit to run Mitsi Galant calipers with built in handbrake:
Ben
kiwitonita
That's a fine looking bit of machining Ben. Do you sell either kit? I had not thought about the handbrake - the centre one seems fine but would be interested in the built-in handbrake. Thanks - Tony.
Ben
Post by Ben »
Hi Tony. Yes, I do sell the kits. I've sent you a PM.
Ben
Return to “Suzuki”
