diff lock
Re: diff lock
coxsy wrote:hi you all i need the electic over vaccum solenoid for rear diff lock on a 89 gq
Coxey, have a read of this thread.
http://www.outerlimits4x4.com/phpBB2/viewtopic.php?t=33706&start=0&postdays=0&postorder=asc&highlight=factory+locker+solenoid
- pathfinder67
- Driver/Navigator
Re: diff lock
I posted details on the forum late last year where to pick up aftermarket solenoids for $180 from an industrial supplier. 24 volt to. Do a seach, it will be under Albundy's posts. You won't get an original, I tried and went the aftermarket way.
Al
Al
Re: diff lock
thanks guys
went to south auckland nissan diff lock soliniod one in stock $470 +gst
Re: diff lock
Not sure if you found Al's old post, if not these guys have suitable solenoids, may or may not be what Al ran.
They are what the ozzy boys are using, and proving popular and reliable, and you only need one, not 2.
http://www.macvalves.co.nz/
More info here on hooking it up
http://carl.outerlimits4x4.com/viewtopi ... c+solenoid
Re: diff lock
went to mac valve up here and they made a solinoid up for me , paid $86 + gst a whole lot better than nissans $470
- Sadam_Husain
- Angry bird
Re: diff lock
So when does it get fitted to the truck coxsy?
Re: diff lock
in due time mate still, lines fitting and wire to find ,fit ,a drag link to replace , my list is long
Re: diff lock
stock $470 +gst
Al
Re: diff lock
hey would anyone have a exploded view of a safari locking diff for me , like to see whats in there
Re: diff lock
coxsy wrote:hey would anyone have a exploded view of a safari locking diff for me , like to see whats in there
Have a look here
http://s166.photobucket.com/albums/u111/spadger83/Nissan%20Patrol%20Factory%20Locker/
Re: diff lock
thanks added to favorites for referance
Re: diff lock
diff soliniods his one
mine will it still operate ok
Re: diff lock
Those are big $$$ to replace too aren't they?
- cool__bananas
Re: diff lock
we have one around here which my dad probably would have given to you for free
Re: diff lock
what the diff or the soliniod?
Re: diff lock
Isn't that the actuator in the pic? I'd make sure you make a plate to protect it from rocks etcThe solenoids are under the bonnet
Re: diff lock
that sounds right, soliniods i have, actuator is pushed in on the end pipe bent, will it still work?
Re: diff lock
I have seen some pretty bent ones that still work, but them I've seen some with little visible damage and they don't.
Not sure whats involved, but you may be able to swap them over to see if the damaged one works?
Just wouldn't want it to partially engage and risk breaking something.......
Re: diff lock
coxsy wrote:diff soliniods his one
Mine looks a shit load more beaten up than that and works fine,I need to put a cover over it...at some stage.
