drz400 wrote: how do you put pictures up on this site.
You will need to put your picture on some free picture sharing website ( I use Photobucket,http://photobucket.com/)
Once your picture is on there you can copy and paste the links provided by Photobucket to get your image in these posts.
Register and upload a pic to Photobucket to see exactly what I mean. But basiscally you will see a picture which you have uploaded with some tags below it for various applications as labelled. Just highlight the required tag, IMG CODE in this case as in the picture below, and this code gets copied to your clipboard.
To insert the image anywhere in you message you press and hold the "Ctrl" and "V" keys on your keyboard at the same time and the code gets copied and pasted and the right image will appear.
Simple as that.
