Heres the background
I bought the "Lemon" an 82 yellow single cab 2L petrol Hilux as a work hack with the intention of using it while I worked on my project truck... it only had to last me a yr well that was the plan
it lasted 3 weeks and in that time I only used it 7 times
Had to fix a leak in the feul tank that someone had used bog to try and seal
I have since then gathered the replacement bits and pieces and done a little bit of work now its time to start putting the Lemon together
I have thrown the old chassi due to rust I could lift the whole chassi by my self easily, with the new one I can only lift one end!!
This is from an 86 double cab project of a mates that never made it out of the shed
He was turning it into a "monster truck"
Its also had all the crap that I don't need removed, things like the old shock towers in the front, shock mounts at the back, cut the back off just past the rear spring mounts and a few other bits have gone
I've also taken the cab outriggers from the 82 chassi (had to rebuild the lower half of two due to rust!) and mounted them in place of the 86 ones.
I've then mounted a surf power steering box for Xover steering, the mount has been recessed in to stop the tires rubbing at lock
Next up is the rear spring shackle mounts make them wider the same width as the XD falcon springs
Cheers Reece
