Flares
- curly12
Re: Flares
Best you get two set's then and fit mine when you get down here because we don't want your new found knowledge going to waste
- Sadam_Husain
- Angry bird
Re: Flares
Might be best if you fit them after rallywoods so you've still got a complete set of 4
Re: Flares
whats the chances of driving down there plus around the north island with 65mm of tyres out passed the guards and not get pulled over
- Sadam_Husain
- Angry bird
Re: Flares
Probably best I dont list all the things I driven around the North Island during my mis-spend youth so point taken coxsy.... shit I dont want to have to pay the ticket for ya
Re: Flares
only an aussie would put fabric tape and and unremovable stickers on wire to be threaded in to rubber
Re: Flares
coxsy wrote:only an aussie would put fabric tape and and unremovable stickers on wire to be threaded in to rubber
Go the garden edging way ... It's cheaper and no wire edge to contend with ...
Re: Flares
thought about it, brought some , used it in the garden
felt to hard to be useful
Re: Flares
they will do for now
Re: Flares
The problem I have with this stuff is it is too rigid and I for one feel if it catches on anything you run the chance of doing panel damage to the guards.
Ph 0212078472
Ph 0212078472
Re: Flares
Another option is conveyor belt offcuts - try Blackwoods, they have a conveyor manufacturing division.
Re: Flares
I had trouble feeding the wire through mine too, i ended up tearing the flares a bit because i was forcing the wire through to much. Ended up installing them with a couple of screws first and getting the right cutout shape then taking them back off, squirt some wd40 down both ends of the flares and then feed the wire through when they aren't mounted on the guards, takes a little longer but much easier,
Re: Flares
thank you I'm not alone in have frustations with them
