now got to get 4 brake lines made for the front 2 shocks for the front and a new exhaust system and we should be rolling
turoa wrote:malcolm, you might want to upgrade the axle studs to 10mm instead of 8's. knowing how you drive you'll break em all the time
Beer_Cruiser wrote:turoa wrote:malcolm, you might want to upgrade the axle studs to 10mm instead of 8's. knowing how you drive you'll break em all the time
That sounds like a good plan.So how do I do that.Just drill out old studs amd retap to 10mm?
lneil wrote:Great afternoon out with Nstg8a, his new Safari makes most of the tracks look easy, while the 'zuk struggles through on the 31's.
I ended up with a smashed grille and torn snorkel-mounts, but still better off than the truck with a stuffed panel and broken driveshaft!
Got a strong suspicion that next weekend will be spent mainly in the garage.
rokhound wrote:Hope you have more than just those tags holding that number plate fweddy. Otherwise the first decent water crossing you do will turn the whole lot inside out. The Hi lift brackets look super sexy though
xj wrote:that top pic is a cracker!!!!!
fweddy wrote:Spent pretty much all of sunday afternoon making these.
What for? To fit here
UBZ wrote:Is that up the Applebby river on the way to Mot? looks familiar.
