T3/T4 turbo ???
T3/T4 turbo ???
I have been offered a T3/T4 turbo at a give away price, I have a turbo manafold ,And this turbo is as new condition , Is it any good for the Nissan??? I know stuff all about turbo's
I want low down power but I want sone top end power as well
HELP
Graham
HELP
Graham
Nissan Safari SWB Auto ,50mm suspension Lift , 50mm body lift, 12000lbs winch,
33x12.5x15 Perilli scorpion muds
Re: T3/T4 turbo ???
There'll be an A/R ratio on the exhaust turbine housing. They've got a big impact on when the turbo starts to spool.
My gut feeling is it's too big to give you the low end you're after. But the numbers will let us know.
Re: T3/T4 turbo ???
I am suprrised I have not got more replys.
The reason;
I have a turbo manafold but unsure of what turbo to use, I have been susjested the T3/T4 and I can get one cheap
What I was hoping for was susjestions of what is the best after market turbo to use with out blowing the budget
Graham
The reason;
Graham
Re: T3/T4 turbo ???
is it a safari? doubt you could go to big. one guy on here has one of a big truck on his and he seemed to think it goes ok.
Pete
Pete
Re: T3/T4 turbo ???
minefield wrote:I am suprrised I have not got more replys.
The reason;
Graham
If your manifold has a T3 flange, then find a T3 from a nissan RB20 or similar. Try to get one without a ceramic exhaust wheel.
Re: T3/T4 turbo ???
I have heard that the RB20 would be ok ,Good low down power but runs out on high rev's, I dont think thats a worry
I would be interested in talking to someone who has that setup
I am a bit worried about the T3/T4 it's one big turbo with a 4" inlet and it's rated for cars to 450hp I am a worried that it will not spool up until high rev's, "This is the reason for this posting"
So I am interested in any more info on the RB20 set up
Graham
Graham
Re: T3/T4 turbo ???
KiwiBacon wrote:There'll be an A/R ratio on the exhaust turbine housing. They've got a big impact on when the turbo starts to spool.
as above..if you can find the A/R ratio on the exhaust this would give you a better idea of how its suited to your engine.
what engine are you running? how many cc etc?
if its a give away price buy it get it bead blasted, sell it for more
you do need to be able to spool the turbo
Ryan.
Re: T3/T4 turbo ???
Graham,
I asume the turbo is for yourTD42.
The A/R best suited for the TD42 Is .48 comp and .83 turbine.
If you do a search on http://www.Patrol4x4.com you will have more information than you will know what to do with.
Jase.
Jase.
Re: T3/T4 turbo ???
minefield wrote:I have heard that the RB20 would be ok ,Good low down power but runs out on high rev's, I dont think thats a worry
The RB25 may also be a larger T3 turbo if you want another option.
The exhaust A/R quoted above is too large for my liking.
Re: T3/T4 turbo ???
I have just had another offer'; A garret T25 off a early model 300sx but the shalf has zerro play ???
Graham
Graham
Re: T3/T4 turbo ???
minefield wrote:I have just had another offer'; A garret T25 off a early model 300sx but the shalf has zerro play ???
Graham
More difficult to fit because the flange is different to the T3.
The smaller T25's are too small for your engine at full noise, if you don't go past 3500rpm often it'll work. The larger T25's sometimes have compressor trim which makes them unsuitable for a low revving diesel.
But the T28's which come on many nissans can be an excellent match.
Re: T3/T4 turbo ???
zero shaft play have you put a DTI on it? they will be full floating bearings there should be play.
Ryan
Ryan
Re: T3/T4 turbo ???
Engineer wrote:zero shaft play have you put a DTI on it? they will be full floating bearings there should be play.
Ryan
Unless it's siezed.
Some nissans had ball-bearing T25's, but I think only on the W11 avenirs with the SR20DET, The CA18DET engines had the journal bearing T25 and most other SR20DET's had T28's.
Re: T3/T4 turbo ???
I got the stat's for the T3/T4 comp .70 Turbine .86 hope that helps
Graham
Graham
Re: T3/T4 turbo ???
minefield wrote:I got the stat's for the T3/T4 comp .70 Turbine .86 hope that helps
Graham
That'd make a good dyno queen, but you'll be missing a lot of low-end boost and drivability.
