Terrano temp problems
For all Nissan related topics
Armz
Post by Armz »
I have a 92 Nissan terrano 2.7t auto, Ive noticed after driving for 20 mins or so there is a shit load of heat comming from the gearbox area, it can mainly be felt comming though the gap round the hand brake, and the bottom of the gear stick is bloody hot to.
The gearbox is running fine, and the guy i brought it off recons he spent $2700 reconditionishing the gear box which would be about 8000ks ago now.
I know heat is the biggest killer of the autoboxes, so any ideas of what to do? or is this normal nissan stuff?
Scarfies on the piss,
long
Re: Terrano temp problems
Post by long »
put an after market trans cooler on it that way it will run a lot cooler as orignal cooler is in the bottom of the raditor so it will heat up the trans flud to running temp or in other words trans temp is only as cool as you engin temp hope this helps
kiwipete
Post by kiwipete »
I agree with what Long has said.
I would also check the rubber seals around the gear levers are in good order too as the transfer lever one tends to split and allows the heat to move up into the cabin, as well as any water too! Simply remove the console around the levers to check this out.
BNT is a good place to go for an after market cooler.
Ph 0212078472
Armz
Post by Armz »
Cheers for the advice guys.
I can understand putting in an aftermarket coolier for offroading or towing, But im wondering if there is something wrong with it thou cuz it gets real hot on just a 20min drive with nothing it in but me drivin going from Dunedin out to Mosgiel which has 2 small arse hills n the rest of its flat.
Is this normal for a terrano??
gary_in_nz
Post by gary_in_nz »
sorry i just gotta say what an awesome avatar!!! on par with>>
long
Post by long »
Armz i guess it is possable that the filter in the injecter pump could be blocked up bad you will find it under the power steer pump there is a 17mm bolt crack it open be careful there r 2 copper washers one on top n one under the banjo fitting move the fitting aside push in a biro u should pull out a spring push it in again and u should get a small filter about the size of your little finger nail blow it clean n reassemble n give it a shot it mite work n it mite not to
albundy
Rolly Polly
Post by albundy »
have you tried the NPORA site in Nth America. These guys are terrano/pathfinder experts.
Al
Armz
Post by Armz »
gary_in_nz wrote:sorry i just gotta say what an awesome avatar!!! on par with>>
Yea Damn cops. Hate them when they giving u fines or making up shit bot liquor causing problems blah blah
But then there ur best mate when sum nigga steals ur truck or breaks in2 ur house, or trya smash you for your shoes (Common problem in Northland, up here atm at the olds place).
albundy wrote:ave you tried the NPORA site in Nth America
Id never heard bot this site before, but damm glad i know bot it now, theres heaps of knowledge and HELPFULL :D advice about real trucks ie Nissan Pathfinders :D :D :D on there highly recommend nissan terrano owners needing help go there for a look, just rename it a pathfinder :oops: and theyl help ya they defently dont like the terrano name on there - they were mean to me about it :cry:
Return to “Nissan”
