i have the engine in and suspension together minus shocks. I flexed it up last night and found that a well under 1000kg buggy cannot flex the bushes inthe rover arms (poosibly to do with the 1000+kg weight difference
Took front bolt out of drivers side and got the flex I was after. Without body, cage etc got just over 700mm under wheel that was in the air.
The Problem - removing the bolt ony works in one direction as radius arm hits axle tube. Cant take both front bolts out.
Solutions - Flag the flex and save the pennies for lockers (may take about 2 years the way things are)
Cut the radius arm on one side so only has one bolt. (prefered option)
Question - Are there any issuse with my prefered option on an off road only truck? Is the single side likely to be strong enough to withstand the torsional forces?
I have looked at wristed radius arms but feel that my option would prevent the rearward moved associated with them.
Any thoughts?? (dont ask for pics camera packed a S*(T and wont be getting new one for a week or so thanks to flybuys)
