twin pipes
- cool__bananas
twin pipes
ive just put twin pipes on my rover v8, should i put a balencer between them? what will change?
Re: twin pipes
the noise
- cool__bananas
Re: twin pipes
better or worse? its all ready rely nice and loud, each side has a small coby and thats it, its 2 1/4 for each side, si will it change the sound much?
- skid
- Tyre Man
Re: twin pipes
cool__bananas wrote:better or worse? its all ready rely nice and loud, each side has a small coby and thats it, its 2 1/4 for each side, si will it change the sound much?
make it smoother sounding, not so harsh
Re: twin pipes
i dont run a ballance pipe on my chev and a 3" muffler on each side and am happy with the sound, at low rpm it sounds a little eratic but when on song its just fkn rad !
have a listen to this
http://s248.photobucket.com/albums/gg19 ... V06212.flv
churr
churr
- cool__bananas
Re: twin pipes
so does it matter how long it is? could it only be like 40mm apart?
- skid
- Tyre Man
Re: twin pipes
cool__bananas wrote:so does it matter how long it is? could it only be like 40mm apart?
any length ya like, coz it will make it sound better.
although if you were get it all into a single pipe to exit the truck, then that would sound even better still
Re: twin pipes
there should be an small performace gain from adding this if your pipes are the right size
without going into harmonics and a loooong droning speach there is a piont on the single pipe where the pressure waves and resonance build up (will cause more heat here as it is stalling the exhust gas) now if you jion to the opposite pipe it will let this build up flow accross and its an easy one to locate you just use the heat, paint your exhust with some paint and run it at running revs 3000-4000 (becouse harmonics wavelength changes depending on revs)... anyway there will be one spot that heats up faster burning the paint, thats your piont you want to put the H pipe in
And yes shorter is better
Cheers Reece
De Ranged Engineering
027 541 8794
027 541 8794
