mercutio wrote:whenever i had a problem on my landrover my first point of call was the points took me a little while to work this out though
now i don't have that problem![]()
turoa wrote:it has electronic ignition and no points
gary_in_nz wrote:what fuel are you running?? i always through 95 in mine, if i leave it sitting around for a while, ie a week or more, i have to remove the plugs and give them a quick clean, one thing i have found is that these motors need to be driven everyday, for a while, once they get warm they arent too bad but need a good run really, quite often.
best of luck
mercutio wrote:what sort of carbs does it have and are the pots filled with the correct amount of oil
