Air Leak
Air Leak
I seem to have an air leak somewhere in my system. It escapes over night.
This is on my on-board air system. I have plumbing from front to rear and a 6ltank.
I have tried all the usual tricks like using soapy water on all connections, but I still cant find the leak.
I did think of putting some dye in the tank with water then pressurising it, but I don't want dye all over the show, especially my drive.
The real issue is that I am manually filling the system at present cos I have yet to install my Sanden AC pump.
What suggestions do you all haveon solving this leak?
Ph 0212078472
Ph 0212078472
- Sadam_Husain
- Angry bird
Re: Air Leak
What did you use as a thread sealer, I had slow leaks with my joints till I used some loctite 567 thread sealant?
Re: Air Leak
Sadam_Husain wrote:What did you use as a thread sealer, I had slow leaks with my joints till I used some loctite 567 thread sealant?
Thread tape, because I want to alter it sometime in the near future. Strange seeing as how it has held up nicely for the past 4-6 months.
Thread tape hasn't been affected on my workshop compressor or fittings in the garage at all and I have had that for 3+ years.
Ph 0212078472
Ph 0212078472
- Sadam_Husain
- Angry bird
Re: Air Leak
Yep I used thread tape before I put the loctite thread sealer on it
The system holds up ok now
Re: Air Leak
And it seems odd that the old trick of the soapy water did not produce any bubbles too.
Ph 0212078472
Ph 0212078472
- Sadam_Husain
- Angry bird
Re: Air Leak
Yeah the leakings probably a bit slow to pick up with soapy water.
Go and shout yourself a $40 tube of that loctite thread sealer
If the 40 bucks is a bit too hard to let go of theres probably lots of other thread pastes you could use?
Re: Air Leak
if there is no external leak then the non return valve is the likely culprit
Re: Air Leak
Pedro wrote:if there is no external leak then the non return valve is the likely culprit
Nope, don't have one in there yet.
Ph 0212078472
Ph 0212078472
Re: Air Leak
make sure you have heaps of detergent in the soapy water. Too little and small leaks don't bubble, as it tends to run off to quickly.
Rowan
KZJ78 LWB Prado
KZJ78 LWB Prado
Re: Air Leak
rowinz wrote:make sure you have heaps of detergent in the soapy water. Too little and small leaks don't bubble, as it tends to run off to quickly.
Yep, did that too thanks.
Still thinking of putting some sort of dye in the tank and pressurising the airlines to spot the leak, but I need some sort of dye that's not going to stain.
Suggestions anyone please ?
Ph 0212078472
Ph 0212078472
Re: Air Leak
NJV6 wrote:One way valve![]()
How do you fill your tank?
Yep, checked all the connections with the soapy water.
I fill it by plugging it into an external air compressor at home or work.
I just havent gotten around to making any brackets to mount my Sanden AC pump yet.
Too lazy i spose.
Ph 0212078472
Ph 0212078472
Re: Air Leak
Yes but how do you connect the compressor at home to the tank?
If it is like this one
Then they are a bit prone to leaking.....
Re: Air Leak
Yep yep, it is the same type of connection that I use.
I would still have thought that the soapy water would have picked up a leak in it too all the same, thanks.
Still looks like a dye is the answer tho.
Ph 0212078472
Ph 0212078472
- Steve_t647
Re: Air Leak
you could go to an aircon place they use a fluro dye to trace leaks pressureise the tank with than and you can only see the dye with a black light, not sure what they would charge you for the dye tho.
