Having just been up the Waimak for a play, im still here as I type actually, I had to use my winch to get out of a tricky spot between a couple of trees.
No the problem is that my winch appears to be dead.
Nothing happening at all when I used the wireles or hand held remotes.
Has anyone had issues with their winch like this?
I will be having a look at it when I get home, but thought id post up just incase someone has suggestions before i get home.
Aint the internet grand when your'e out n about?
Runva Winch Woes
Runva Winch Woes
Ph 0212078472
Ph 0212078472
- northland_pajero
Re: Runva Winch Woes
mine has done the same thing (three times)...
first time it was the solonoid control box, replaced under warranty (other symptom clicking sounds when tryin to use the winch)
second time was a loose connection in the the controller, by taking it apart and tightening the ring around the one off swith (symptom, the one off switch fell out of the controller)
third time it was the motor, replaced under warranty, hopefully I just got a faulty unit and now with everything replaced it should be all good, I have to say Michael (they guy I bought it off on trademe) was incredibly helpful and eplaced the borken parts without question, symptom the motor was slow then it died, once agn with the clicking sounds.
No.. Havent had a problem like that.... did have the following problems with my 24v 10000lb one: Cable bunches on the right side for some reason,ended up beaking the mounts where the rods hold the winch together..and the clutch wont release and freespool for some reason....
Thanks guys, im back home now and as soon as I get a clear spot from the rain I will put a multimeter over it to see whet is the prob.
It will be a right PITA if I have to ship it back!
Ph 0212078472
Ph 0212078472
Sorted,
it was that stupid red switch on top of the relay box. It wasn't working so I have now wired a new switch into the dashboard to keep it out of the moisture.
I know these are a cheaper version of a winch etc, but why do they bother with such crappy switches.
Ph 0212078472
Ph 0212078472
