Lifting rear shock mounts(GQ)
For all Nissan related topics
Shane
Post by Shane »
Thought I'd but this in Nissan section as well as weekends achievments
Liftin rear shock mounts
started rear shock mount Lift
Idear is to lift rear shock mounts so its less likely to get bashed on stuff which it does do and side benefit being it well let the wheel drop alittle further for better artic.I have measured shock to make sure it wont bottom out.
Std mount before work started VVV
Mount cut off with cutting disc,cut approx 40mm out of middle section of mount and reused lower section which was welded back to diff. VVV
Lower section welded back in place VVV
Only done right side you should be able to see the differance from left,well do left side this weekend.hardest part was making sure lower section pin was correct alignment so it wont slog out the shock seals.well give it a flex test on weekend so if theres any noticeable change.
gary_in_nz
Re: Lifting rear shock mounts(GQ)
Post by gary_in_nz »
looks good have to see the articulation pics
Shane
Post by Shane »
gary_in_nz wrote:looks good have to see the articulation pics
Welded left side in place just need to add bracing at some stage for extra strenght,have made a calculation error mainly due to shock being on a angle,lifted mount approx 40mm which only gives the shock about 25mm extra drop so only a small gain maybe 35mm at wheel. :oops: dum ass ...spring is still tight in saddle
Went down river for a quick flex test,factory sway bar disconnected at control lever(still limits alittle)left rear tyre still not touching inner guard,35psi in tyres, is better for sure but probley could have got abit more out of it.worth while doing that's for sure.
Shane
MudBum
Post by MudBum »
Nice Shane..going to do mine shortly..was going to buy the kit from Aussie but might follow your lead and do it ourselves. 8)
***Prior Preparation Prevents Piss Poor Performance***
Most sports require only one ball - real sports require two.
Return to “Nissan”
