bloody terrano
bloody terrano
Re: bloody terrano
well i pulled a motor and box out not so long ago,i seperated the 2....pulled both out up the engine bay without taking the diff out
if its gonig as scrap you may aswell cut the front end off...or atleast remove the radiator and cut the rad support out,makes it a shitload easier...
if you have,use a tractor...since body is going to scrappy it wont matter???
i did that and had very minimal damage to firewall caused by gearbox. so it is possible to be nice to it all.
good luck.
good luck.
Re: bloody terrano
yea i have cut the front off it but the sump will not clear the diff this is the worst car ive ever worked on. Im about to go have anouther go at it now so ill try again with it
Re: bloody terrano
i couldnt believe it i walked out side pushed the pig out of the garage hooked up the engine crane and it lifted stright out. After the all the trouble i had last night with it. Oh well its off to the scrap yard
Re: bloody terrano
Sweeeeet.
Was going to say,it should be a problem.wasnt for me
Re: bloody terrano
yea but they are still a prick to work on. I shouldnt complain tho i only paid $200 for the wrec and thats cheap for a good spare 5 speed box and 2.7 deisel motor
